Previous in Forum: Frigidaire Freezer rust forming after only 2.5 years   Next in Forum: history of flat glass
21 comments
Reading books during traveling?
01/02/2010 12:24 AM
I am sory for asking an out of forum question but I am wondering for its answer. It is generally said that reading books etc. is prohibited during sitting in bus and traveling on road because it has negative effects on eyes. Is it true?
Re: Reading books during traveling?
01/02/2010 12:55 AM
For some people, the process of keeping the eyes focused on a slightly moving/jiggling target (the book) may be tiring or even carsickness inducing. I don't know of any optical ill effects. A medical forum might be more informative.
01/04/2010 1:04 AM
Epileptics can get a seizure triggered by oscillations at certain frequencies.
Seizures have been reported in persons in buses moving under a canopy of trees, where the dappled sunlight matched the trigger frequency.
Am seventy one and have been reading in moving vehicles all my adult years without any demonstrable ill effects.
01/02/2010 4:34 AM
This is very true - if the person in question is driving the bus.
Not related to your question, but my optician tells me that sitting too close to the TV is not bad for the eyes (contrary to popular belief).
When ballet dancers do that pirouette thing, they fix their eyes on a particular spot in the theatre. As the body rotates, they quickly snap their head around to keep looking back at that fixed spot. This stops them getting giddy. Not sure if that relates to your question either, but it may in part.
If reading on a bus was bad for the eyes, I reckon that you would either be unable to focus, or a headache/whatever would tell you to stop.
I once got into trouble for reading a magazine on a train, but it's not something I'd like to elaborate on .
01/02/2010 5:44 AM
Had you been reading the articles, rather than the pictures, you might have avoided this repercussion. But then, busybodies looking over your shoulder.... I understand perfectly.
01/02/2010 6:31 AM
I wouldn't feel so aggrieved, but for the fact I was trying to hide it inside a copy of Playboy ! My eyesight seems to fade with each year, so I suspect my fathers advice about 'it'll make you go blind, son' may be true . I hope my sharing this experience will save other compulsive bus readers - Gents, only read at home and in the presence of spouse.
Good Answers: 143
01/02/2010 9:03 AM
I'll try to stay away from the medical end, but I worked as a bioengineer in a vestibular lab for some time and know the phenomenum you refer to. Your vestibular system (inner ear) contains a number of accelerometers, both linear and angular, that feed into the cerebellum to enable the vestibulo-occular reflex (VOR) that normally moves your eyes against head movement in such a way as to keep images steady on your retina (For those of you that know any neurophysiology, I just did a whole bunch of hand-waving and muttering). Anyway, when you're reading, you're fixating your gaze on the written words and suppressing that VOR. Your brain notices that it is getting movement input from the vestibular system, but the eyes are not seeing movement and thinks something is out of whack. Possibly, we retain an evolutionary artifact that, when vision gets screwed up like, we empty our stomachs in an attempt to combat poisoning. It's the same response as when we drink too much booze and mess up the density balance between the perilymph and endolymph - up comes dinner!
I used to spin people in a rotary chair with goggles on so they had no visual input. If I would suddenly ramp down the velocity, I had to be prepared to duck out of the way of projectile vomiting.
So, instead of reading, trying finding license plates for each of the 50 states. Or watch for Burma-Shave signs.
Good Answers: 62
01/02/2010 11:25 AM
Having had about 2900 flight hours to experiment with this phenom I concur with your observations
The other intruding effect being "sympathy" puking.
Once one crew member "popped" the odds of follow-on went up prodigiously.
Good Answers: 143
01/02/2010 11:59 AM
Yep, very akin to quickly looking down at the control panel while in a tight turn. Tends to cause, as one Air Force major put it, "coincidence with terrain".
01/03/2010 11:12 AM
I've found that you can stimulate the pv reflex by having the nurse use one of those vibratory ear syringe substitutes, with cold water. In just a couple of minutes you can be writhing on the floor with cebum intactum and ocular spinnyroundus.
I believe these devices were introduced into the UK as a safety measure.
Fortunately Spain still uses the old fashioned version which works a treat.
duikerbok
Good Answers: 143
01/03/2010 1:56 PM
Yep, they work well and are used in the US. They have a very low bandwidth.
Good Answers: 93
01/02/2010 1:25 PM
The others have given some interesting information. Nice to have the mention of ballet which I grew to like to watch. Nice that it is okay to stare at ballerinas and strippers while sitting in the dark.
Which brings us to the influence of the dark.
I have often read books on buses, trains, and even on planes, without experiencing any particular nausea or headaches.
Could be I just got used to it, though I know I was more likely to be reading while traveling at night, than during the day, and wonder if that might have obviated any ill effects. I suspect that it is easier to focus on the point lit page when moving, and it is dark out the window, than when it is lit out the window and a bunch of stuff is going by in the edges of your eyesight.
Speed is likely as well a factor. I suspect constant speed in one direction will allow less likelihood of nausea, or headache regardless of the lighting.
Further I suspect that your age has influence for I do remember discomforts either personally or among my siblings when traveling in cars that I haven't experienced much as an adult.
While some say there is a negative effect, overall the evidence would not support this much since it is very common for adults to read on trains and buses.
Overall I'd say to answer your question directly, no it is not true.
Staring at the Sun, is another matter, and is known to hurt your eyes.
Welding without eye protection isn't recommended either, nor should you stare into laser beams.
You don't get wise because you got old, you get old because you were wise.
Good Answers: 97
01/02/2010 5:02 PM
I've never known the reading of books to be prohibited when a passenger on a bus though I've been discouraged because it is said to cause motion sickness. I haven't experienced the sickness because I ignore all else when reading which seems to annoy some others sometimes.
Possibly reading on the bus is not encouraged due the discomfort of close quarters and the result someone's sickness. I remember when in the USN having the top bunk was advantageous at times and reading didn't seem to help those with motion sickness or was me eating raw oysters while smoking a cigar that caused them discomfort
01/02/2010 5:58 PM
That whole sea-sickness thing is odd. Couple of days ago I watched a re-run of Lobster-Men (or whatever it was called on the Sky docu channels). The guy had been at sea before, but that time it just hit him. Sea-sick for about 4 days, throwing up etc. He wound up so dehydrated his body went into convulsions. The Coastguard and ship crew pulled off an amazing nighttime rescue - a couple of hours later and he'd have been dead. Awesome good how they all did it. Main lesson I observed was that if you get sick like that, getting fluid into the body is the most important thing. You can go for weeks without food if needs be, but without water you're a gonner.
Good Answers: 143
01/02/2010 6:50 PM
I sailed back from Germany in a small troopship (under 300 ft long) and we hit a hurricane as we came out of the English Channel. Probably 90% of the troops were violently ill and the check valves failed on some of the toilet tanks. So, there was this really sweet smelling multi-colored bilge that sort of ran anywhere you might be. They had IVs in probably a third the guys. Another GI and I found a odd little stairway (darn Navy calls 'em ladders) that led up in front of some kind of airshaft where the officers on the bridge couldn't see us and the waves wouldn't hit us. We swiped some rope off the rail and tied ourselves so we couldn't wash away. But, being able to see the horizon (and not smell the interior) made the difference. I went to the ship's store and bought as much cheese and chocolate as I could and we ate that for the roughest three days. We'd go inside to dry off and warm up and at night to sleep (the trick is to tie yourself in your bunk and interlace your fingers in the springs of the bunk above), but that being able to see made all the difference. That, and long experience with shoveling pig manure had just about made me immune to bad smells. They literally carried a heck of a lot of those GIs off when we got to Brooklyn. I had forgotten that till you just reminded me.
Good Answers: 97
01/02/2010 11:56 PM
Whatever works...the least movement is found center and as low as possible.
Good Answers: 143
01/03/2010 8:32 AM
Yes. Unfortunately, my compartment was in the bow at the top (whatever sailors call that). It was kinda fun once I figured out I wasn't gonna die.
01/03/2010 4:28 AM
I'm not sure whether to apologize, or say 'you're welcome' ! Top notch anecdote TVP - I wish we had that extra button to rate posts as worth reading.
Good Answers: 97
01/02/2010 11:54 PM
We administered Pedialyte from a eye dropper to keep hydrated sometimes when they couldn't take much at a time. It acts much as an IV to stabilize the electrolytes.
Good Answers: 25
01/03/2010 2:24 AM
Hi Signode,
It depends on the condition of the road you are travelling. If roads in Lahore are bumpy then may be your eyes may get strained. I used to read my morning newspaper in local metro trains in Mumbai, it has never affected my eyes. May be rail travel is smoother than road.
Suresh Sharma.
Good Answers: 42
01/03/2010 10:00 AM
There is no prohibition like that sort being imposed any where.
What could be worth saying is reading is not advisable during travelling, which is again depend upon your mode of travel.
During travelling -by cars,bus etc, the vibrations, jolting usually disturb steady holding of the book, head, spinal, legs being under constant shaking's ,reading is no more worth. The strain caused as well as disturbances makes reading no more enjoyable and sure to strain eyes in the long run.
Flight journeys and next train journeys are better for reading because of the steady state of disposition. Boring long journeys reading could be the best time pass.
Other aspects of reading in buses- you may miss the stopping's, distraction by co passengers, lack of vigilance on personal possessions etc.The audios, blasting videos in public buses are other menaces for reading as well bother pleasantness of the journey.
The best way to enjoy travel is to take long breaths, keep a relaxed mind, see landscapes and free one's mind.
BEST CREATIVE IDEAS FREQUENTLY COME DURING RELAXED LONG JOURNEYS.CATCH THEM UP.
Nature is so graceful and naked. Human possession is ridiculous.
01/06/2010 5:15 AM
Thanks a lot. Very useful info flound.
Register to Reply 21 comments
Anonymous Poster (1); bwire (3); duikerbok (1); edignan (1); Kris (4); s.udhayamarthandan (1); Signode (1); suresh sharma (1); Tornado (2); Transcendian (1); TVP45 (5)
