Previous in Forum: XOX Bolts and Nuts   Next in Forum: PJP Welding vs. CJP Welding
8 comments
Bonding Aluminum 7075
01/05/2010 7:07 AM
I am trying to find a braze or soldering compound to join two "hockey pucks" of 7075 aluminum together. The 7075 has a melting point of 1175F, and there are holes in the pucks that need to maintain their integrity, so it needs to be a low temperature. I will be using a small annealing oven as the heating source. I have tried the usual search engines, and found nothing helpful, I am hoping somebody here has some experience in aluminum bonding.
Thanks in advance...
Re: Bonding aluminum 7075
01/05/2010 7:09 AM
Check out HTS 2000 aluminum brazing.Low temp, high strength brazing.
HTRN
Good Answers: 109
Re: Bonding Aluminum 7075
01/06/2010 2:41 AM
Why braze, why not glue?
High temperature (150 to 170°C) curing epoxi with residual elasticity would do!
Do not exceed 170°C for more than 2 hours else you will change the temper status of the 7075.
RHABE
01/06/2010 4:56 AM
GA as thats exactly what I woould do, after really intimate cleaning and slight roughening of the two surfaces to be glued.
Good Answers: 94
01/06/2010 5:32 AM
Would Durafix do it? I've used this with a propane torch & it produced a joint as strong as the parts being joined. The braze temp is well below your material limit.
01/06/2010 6:42 AM
I guess I should have added that antifreeze will be flowing through these, so there can be no leaks. I will be pumping the antifreeze at 20LPM. I haven't found a suitable glue that will handle the temperature change that I put this through. From the cold of Michigan winters to the heat of the summer. Glues that I have found won't handle the temp swings.
Thanks for the replies.
01/06/2010 1:14 PM
Quality epoxy, check the maker's specs before buying.
Good Answers: 94
01/08/2010 4:18 AM
This from a recent NASA bulletin;
A truly remarkable, innovative epoxy adhesive, sealant, and protective coating has gained widespread acceptance for service at cryogenic temperatures. Master Bond EP29LPSP not only functions at temperatures as low as 4 degrees K, but also withstands cryogenic shocks (i.e., from room temperature down to liquid helium temperatures in a 5-10 minute time period). Additionally, it meets NASA low-outgassing requirements.
Might be worth checking out their products.
Good Answers: 58
01/06/2010 8:28 AM
You might think about laser or e-beam welding around the perimeter of these pucks, but why not treat them as you would a pipe flange, and either bolt or clamp them with an O-ring between them?
Andy Germany (2); Anonymous Poster (2); Nigh (2); RHABE (1); welderman (1)
