Previous in Forum: VFD Faults   Next in Forum: Siemens Thyripart AVR
Conversion for Stamford 300kW 480V to 120 / 208v
01/05/2010 11:03 PM
We purchased a Stamford Generator (300 kW) wired 480V 3 ph. and would like to convert to 120 / 208. Can anyone assist with a connection diagram.
Re: Conversion for Stamford 300kW 480V to 120 / 208v
01/05/2010 11:34 PM
I wonder which would cost more: said conversion, or a 375 KVA 480 x 208 transformer....
01/06/2010 7:15 AM
bree218; check & see if you 9 leads/12 leads coming out of the generator, if it could be reconnected in junction box, the control may have be modified, current xformer changed, voltage regulator, scales, etc .perry
Good Answers: 18
01/07/2010 7:25 AM
I doubt that a voltage conversion would be feasible, unless the generator was manufactured with that capability. Check Tornado's answer.
01/07/2010 10:38 AM
Buy and install a suitable step down transformer that meets your required voltage.They are in the market.The connection diagram is in the manual too.
Patrick Whowha
Patrick Whowha
01/07/2010 11:08 AM
In that small size range they are typically 12 lead and easily reconnectable. Tech info is available at:http://www.cumminsgeneratortechnologies.com/en/products/stamford/
Anonymous Poster (1); GRAY HAIRED OLD GOAT (1); Patrick Whowha (1); perry (1); Tornado (1)
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
