Previous in Forum: Member   Next in Forum: Generator Overcurrent
heater operation
01/10/2010 12:17 AM
We have three heaters 75KW and we need suitable schedule to operate only one with the keep other two as stand by and informed we are in humidity area i mean to change weekly or every three days for save them long time
Re: heater operation
01/10/2010 4:25 AM
OK. Go on.....
01/10/2010 11:58 AM
Margini
As PW said, we need some more information. What do you want?
01/11/2010 1:26 AM
Need more information to suggest suitable solution to your question. I assume that the heater is used for dehumidification purpose. Set the humidistat with timer and operate the heaters. You can also consider using the haters in various banks. As per the requirements of the control system the heater will come into operation.
01/11/2010 6:35 AM
Since u are keeping the other two heaters on standby,in order not to keep them for too long as well as to watch their performance,and any unforseen problem that might occur as a result of too long idle period,u may need to operate each one every 24hours(schedule).
It is better to have them working than keeping them idle for too long,bcos some equipments when kept idle for too long may develop problem when u later want to use them,either due to some environmental reactions or attacks on some parts.
Patrick Whowha
Patrick Whowha
01/11/2010 7:07 AM
YOU HAVE THREE MAIN CAUSES OF DETERIORATION, CORROSION, EXPANSION AND CONTRACTION DUE TO TEMERATURE CHANGE AND IF THEY ARE ON CONTACTORS, BURNED CONTACTS. IF YOU PUT THEM ON SCR'S ( ELECTRONIC RELAYS) YOU CAN MAINTAIN CONSISTENT TEMPERATURE, REDUCE EXPANSION AND CONTRACTION AND ELIMINATE CONTACTOR FAILURE.YOU WILL ALSO REDUCE DUST ACCUMULATIONS WHICH ALSO CREATES DETERIORATION. CORROSION WILL STILL BE UNAVOIDABLE BUT RESTRINGING ELEMENTS IS EASY AND INEXPENSIVE. THIS GIVES YOU THE MOST ECONOMY IN TERMS OF MAINTENANCE AND POWER CONSUMPTION WHILE MAINTAINING VERY CLOSE TEMPERATURE CONTROL.
PLEASE FORGIVE THE CAPS, I CAN'T TYPE.
01/11/2010 7:40 AM
my question we have 3 boilers say A, B and C 75KW in oil field our operation base procedure weekly is it suitable or better to minimize to every 3 days or to increase to two weeks to save boilers long time.
05/16/2011 6:54 AM
It is not possible to see from here.
Register to Reply 7 comments
CONWAYMECH (1); margani (1); mrswamy (1); Patrick Whowha (1); PWSlack (2); wareagle (1)
