I'm trying to build a bunk blower with a old Harvestor blower that use to blow feed stuff into a bin maybe 20 to 30 foot into this bin. It is run from a tractor pto at 750 rpm. I put a 10 foot piece of flex pipe on the end to try and blow the snow out of the bunk. It will not. Is it, that I got to restrict the inlet end down more to create pressure to get more velocityor restrict the outlet end? We have not got a clean curve of flow out the end as we used a ninety degree pipe from the end as I think that cuts flow also. It is about a 6" to 8" pipe out this blower
