Previous in Forum: Types of Differential Relays   Next in Forum: Nuclear Waste
16 comments
Water Pipe Corrosion Due to Grounding Problem?
01/20/2010 11:16 AM
I have been living in my new house for 2 months now, and have noticed blue stains in the sink and shower. When filling a bathtub with hot or cold water, the water is blue-tinged. Also I can see a lot of corrosion in the sink faucets. I think it is obvious I am having a water pipe corrosion problem.
I had the city in to test the water, and they said the softener is working and the chlorine level is fine. He said he saw a bit more corrosion on the outside of the pipes than he would expect (the house is 7 years old). He thought it could be a grounding problem and that is how I got pointed in this direction. The city told me that I have plastic water mains under the ground outside my house, so am not connected to a large ground, and am supposed to have a local ground just for my house.
Using a multimeter, I checked DC voltage across the water meter (0V), water softener (0V), hot water heater (0.1mV) and to the natural gas pipes (0V). Before the meter, there is a ground wire connected to the pipe that goes into the cement in my basement. I also noticed that a natural gas pipe touches the heating duct from the furnace in one spot and I isolated it with electrical tape last night.
I would greatly appreciated any ideas or suggestions based on experience with this problem, or something similar. From my understanding this water may not be safe to drink and I am having a baby in 2 months, and am concerned for our safety if our water has high copper levels. I don't even know if I need to hire an electrician or a plumber!
Thanks very much for your time.
Jennifer
Good Answers: 804
Re: Water pipe corrosion due to grounding problem?
01/20/2010 12:29 PM
First you have to eliminate other issues. Copper pipe corrosion, as evidenced by your blue stains, is a serious problem. You should immediately find a test lab to test a sample of the tap water for copper, a level of over 1.0 mg/L is considered toxic to humans and a fetus would be especially susceptible. Mind you, that's a LOT of copper and most likely you would see a greenish tint to a clear glass of it.
Here are the worst offenders causing pipe corrosion in order of prevalence:
• Low pH (acid water) typically found on private well water, but is also present in some small municipal water systems. Again, a test lab could find that too.
• Other water chemistry causes, such as high levels of dissolved oxygen, high levels of salts dissolved in the water (your softener?), and/ or corrosion-causing bacteria such as sulfate or iron bacteria. More test lab stuff.
• Electrochemical causes, such as improper grounding of electrical appliances to the copper piping.
• High velocity of water, relative to size of piping, causing hydraulic wear on the piping, for instance a recirculating hot water system with a pump driving the water through pipes that are too small in diameter. Not likely unless you have a recirc system.
• Poor plumbing installation practices, including not cleaning or de-burring the pipe properly and the use of excessive flux in soldereing the pipe fittings. Again not likely unless the previous owner knew and did nothing about it (in which case, research "lemon laws")
• Sand, sediment or other grit causing hydraulic wear on the piping. Not likely unless it is well water.
• Lightening strikes to utility poles where the electricity travels to ground wires connecting to piping systems.
An electrician can easily eliminate the grounding and/or lightning strike issues (which translates to a grounding problem as well). But here are some suspects from what you said.
Using only water pipes for grounding is now considered to be bad practice. New installations typically require a separate ground rod to be driven into the earth near the house. It may, or may not, be connected to the water pie as a part of the overall grounding system, but the rules or using ONLY water pipes are now very complex and it's usually not worth the effort compared to just doing it right.
Your system may in fact have (or HAD) the proper grounding method because at 7 years old, it should have been inspected against the latest codes. But sometimes people move into a new house and don't like the aesthetics of that copper wire going to a rod in the ground, so they remove it and think it's OK to just connect to a water pipe just like they saw their grandpappy do. A qualified electrician would be the one to find out for you.
So here is what I would so in order or priority and elimination of causes:
1) Test a sample for the above issues, you need to know immediately if you should start buying bottled water or install a filter and if there are chemical issues that need to be dealt with. If there are, an electrician or plumber would not solve the problem.
2) If everything comes back clean in terms of chemical causes, hire an electrician or a home inspector with an electrical background who understands proper grounding techniques.
3) If all of those issues are found to be non-contributing, then get a plumber involved. Could just be a bad installation 7 years ago and the previous owners pawned the problem off on you.
4) If that's the case, then go see a lawyer!
01/20/2010 12:54 PM
Jennifer,
I have my doubts that you have a grounding problem. Your numbers with the multimeter bear this out and it wouldn't cause this type of problem anyway.
If your supply pipes ( after the plastic mains pipe ) are all copper then I would suggest that you are not seeing oxidation (corrosion of a metal eg iron , by oxygen) of the pipe. Copper pipes are used specifically because they won't oxidize. (Likewise when lead pipes were used before copper.) You might see some discolouration of the flux used around soldered joints along the pipe. Excess flux will oxidize on the outside of the pipe but the copper pipe will be fine.
Corrosion of the outside of your pipes would not imply anything about the quality of the water they were carrying unless the pipe was holed and there was some ingress of contamination into the pipe. This is possible but unlikely because the water pressure will cause leakage 'out' rather than ingress 'in'. So , my conclusion is that 'man from city water authority' he confuse issue.
It is possible to obtain simple water testing kits for specific metals. They are also fairly cheap to buy. Any chemical lab doing routine water testing would have a kit for copper. ( Or a school/ college lab, perhaps ? ) I would also consider checking with your neighbours to see if the problem is specific to youself or not.
I definitely wouldn't hire a plumber or electrican yet. They won't be able to help. The problem is almost certain to be related to the mains water supply.
Rob
01/20/2010 11:06 PM
I agree with you. In the past I was involved in a lot of copper pipe retrofits, and where blue and green staining was observed it was almost always due to high chlorine levels. As a side note, if this is the case, then city officials are unlikely to disclose this. Having the water chemically tested by an independent third party would be the way to go. Also, check with the neighbours, as it likely is not an isolated problem.
Cheers,
Duane
Good Answers: 73
01/20/2010 12:55 PM
Hello Jennifer,
I would expect that you will get a lot of hits on this problem. It used to be quite common, especially in New York City high rise buildings at one time. In some cases the copper lines would deteriorate until the plumbing had to be replaced. And plumbers really hate it when electricians use the plumbing as a grounding rod.
National Electric Code requires a 10' by 1/2" copper rod to be driven into the ground for proper electrical grounding. What caused problems with the above mentioned plumbing was that several electrical distribution boxes were all tying into the same copper line which set up a series of "ground loop" circuits that conducted just enough current to carry off copper ions until the pipe was so thin that it started leaking all over the place. Very expensive to repair. Since you are seeing blue stains, it is highly likely that some copper is being leached from either copper or brass fittings and it doesn't take a lot of current to achieve that. It doesn't have to be DC either.
The easiest measurement (using the AC voltage scale first, and then try the DC scale) would be to temporarily disconnect the grounding wire and see if there is any significant voltage (greater than 2 volts) between the wire and the pipe. Some warning, however, because at this point you don't know what the voltage will be until you measure it. And a shock potential may exist if it is greater than 50 volts. The shock potential begins as soon as the contact is broken between the wire and pipe.
After you have measured the "open circuit voltage" you will need to close it by reconnecting until you can have a qualified electrician make the correction. It is entirely possible that some undetected wiring shortcut inside the house is responsible for this.
As to the health hazard, I am not a medical professional but I don't think you are in danger. Copper is one of the components in some multivitamins but it may be in a more friendly form than compound in your water. You might also want to contact the water softener company and ask them about purification testing.
Good Answers: 109
Re: Water Pipe Corrosion Due to Grounding Problem?
01/20/2010 11:14 PM
Hi Jennifer:
I have read some good advice in this thread. You did not say anything about the quality of your water as delivered by the city. I would guess it is hard as you have a softener. The city is obligated to test the water for many things including heavy metals on a schedule and throughout the distribution system. If there is a problem with the city water they would be obligated to notify you. That said there can be issues with corrosive index and you should demand the city do several tests for Langlier's Index for corrosiveness. This is an established index that combines factors like dissolved solids, pH, alkalinity, calcium, and temperature. Softened water will have a much higher level of corrosiveness than unsoftened. The city should be able to provide you with the hard water levels and should be calculated over several temperatures including the coldest and hottest levels.
Once you have established the LI you can begin to take action. It would seem that you may need dielectric unions to help break the potential for galvanic cell corrosion. It occurs wherever two different metals join. Water high in mineral salts is a very good electrolite. Galvanic cell causes ions of two different metals to migrate from one side to the other. Copper will deposit on zinc for example.Hot water tanks, kitchen faucets, and other areas you see these blue deposits (copper) are potential areas for correction. You should also check lead... even if lead solder has been banned for several decades now. Lead solder is still available on the market but is restricted for use on heating systems not potable water. It may have been used and I would not take a chance with a new born expected. It should be sampled immediately after the taps have been idle for overnight (do not flush the taps before sampling) and then sampled after the tap has run for several minutes.
Last, if you have other issues like high chlorine residuals, hydrogen sulphide, or just "salty" water corrosion will be a difficult issue for you. other remedies will be suggested if these are an issue. Good Luck
Good Answers: 203
01/21/2010 12:08 AM
Jennifer-
Had the same problem in my first house--->
No disrespect intended to most of the previous posters but your problem is not one of quantum chemistry, drip pans for grid leaks, exotic grounding malfunctions, induced NEMA code violations with stray electron fields caused by black holes or anything else exotic. You don't even need a good multimeter!
The guy from the water company, like most water company employees, is a wanabe plumber who listened intently while he was going through the company training. Problem was the water company didn't explain copper salts or anything sinilar to their employees. When the guy said the water quality was OK or good did he do any kind test in front of you? Chlorine levels differ dramatically within a water system by location, by time of day, day of the week, season of the year, and also by the source of the water.
The blue tinge is caused by the copper of the pipes reacting with free chlorine from the water. The water company probably has high levels of chlorine in the water to counteract some problem or doesn't know they have a problem. Water companies inject chlorine based on lbs of Cl2 per a volume of water and only run crude chlorine wet chemistry test to verify there injection rates.
The resultant Copper Chloride causes the blue color in the water and possibly you may detect a slight odor of chlorine in the water. At those concentrations it is not hazardous to you but I wouldn't take chances with the fetus, bottled water is a very good alternative at this time.
When I had the problem the water co. swore that quality of the water was excellent and that they had no problems. Why then did the water smell slightly like chlorine all the time and have an even stronger odor on Sundays and especially during the winter? Turns out they were cleaning there system with chlorine on sundays and because they were drawing water from a canal during the winter they were injecting more chlorine than during the summer. Finally I took my swimming pool test kit and tested the water for chlorine, a level much higher than drinking water. I registered on the swimming pool test kit. I then verified this by having some tested in a lab and the results were super high chlorine levels. The water co then fixed the problem.
This is a periodic problem in many locations. 9 out 10 times this is the problem. Try draining some water out of the bottom of your water heater tank into a white bucket. Don't be suprised if you find some bluish-green particles in it caused by the various copper chlorides.
01/21/2010 1:20 AM
Again, I agree that it is chlorine. In my studies I found this type of problem was typically found near the municipal water supply treatment facility or by re-chlorination centres. I have tested many buildings and the results were consistent in the buildings near the aforementioned centres.
As a note, disinfection byproducts can be toxic, carcinogenic and exposure in a shower could affect the respiratory tract, etc. If you want to know all about the dangers research (google) trihalomethanes and disinfection by-products.
01/21/2010 5:54 AM
Under British Standard 7671, the use of water, gas or other utility services as an earth electrode is no longer permitted; gas for obvious reasons, and gas and others because of the increasing use of non-metallic pipework in the utility supply network.
Check for Ω between the building circuit earth wiring and each utility.
Check the Wikipedia article on earthing systems. Depending upon the locality and the method of supply, it may be up to the householder to install an earth electrode under TT arrangements, particularly in rural districts where an overhead supply earth might be disconnected by a falling tree branch. If TT is required, then a 100mA residual current circuit breaker on the incoming supply is highly recommended so as to provide for the possibility of a high earth return resistance at the electrode. If not, then it is probably up to the utility supplier to install earthing, under one of either TN-C, TN-S or TN-CS arrangements.
Once these are out of the way, the rest is something to do with either a water-connected appliance or a water supply problem either in the home or upstream of it, in which case, follow the advice above.
01/21/2010 7:57 AM
I read many of the responses and am impressed at the wealth of knowledge available about this problem. A question to you is was your house winterized? If so flushing your water heater may be a solution if there is a possiblility of that it was filled with any winterization solution. This may be a non-issue if the water testing done thus far hasn't pointed towards this.
-just a thought.
Location: Wake Forest, NC USA (in Central NC, God's country)
01/21/2010 8:29 AM
Since you had the city test your water, I presume you are on their water system. But in case you have a well and were only asking them as an independent, it is possible that you have acidic water (pH less than 5.5). This is a common cause of "leached out" copper from pipes and is characterized by blue staining. Down here in central NC (granite country) well water is frequently acidic and a water softener system is employed to neutralize the water in the first step and then an ion exchange column is used to remove the resulting hardness. If the neutralizer part of system is not working properly, you can have soft but acidic water.
“Better to remain silent and be thought a fool than to speak out and remove all doubt. - Abraham Lincoln”
01/21/2010 10:16 AM
Have you had any sheetrock installled? Check to see if it came from China if so then the sheetrock is causing your trouble and will have to removed for you will get real sick. It make all metal in the house corrode and silverware also.
01/21/2010 11:48 AM
Huh?
Can you substantiate or document this comment about Chinese drywall?
If yes, would you do so, please.
[edit] After posting, I googled, and substantiated... WOW!
http://www.usatoday.com/money/economy/housing/2009-03-16-chinese-drywall-sulfur_N.htm
WOW again! A year and a half ago, and this is the first I have heard of this... I gotta join this current fad of keeping up with the news! There are several internet bits about this issue.
01/21/2010 12:45 PM
I wouldn't advise anyone to ingest tap water, whether from city service or private well, especially in these times, with lots of pollutant sources, but also with inexpensive under-the-sink activated charcoal filtering systems freely available. Whatever your success in correcting your problem, Jennifer, be sure to install a good quality charcoal filter and use tap water only for washing, not for eating.
09/15/2010 4:44 PM
Hi Jennifer,
I am sure you do not have a proper grounding. I have experienced similar problems and it would take too long to explain it here but I think I have an solutions to this problem. I suspect that due to increased Harmonic Distortion on our electrical systems today due to increased use of switch mode power supplies(in most electronics today) that we have more problems with EMF from high frequency.
Solution – you must put down two to three grounding rods in your yard at least 2-4m deep(ab.6-12feet) then attach 35mm²(ab.2 AWG) fine copper wire to the rods and connect them together and for best result measure the ground resistance - must be less than 5 ohms. Then place a copper bush bar(the bus bar is your main grounding) close to your water pipes and connect your grounding wire to it, then you must take a separate fine copper wire(3-4AWG) from that bus bar to your water pipe and other metal part of your building such as steel beams etc. + you have to connect separate wire from your power cabinet grounding to the bus bar.
Ps hope this goes well
svanbjorn@internet.is
10/14/2026 6:02 PM
From what you’ve described, I wouldn’t jump to the conclusion that it’s a grounding issue just yet. Blue or blue-green stains, tinted water, and corrosion around the faucets can be signs of copper corrosion, but there could be other causes as well. The fact that it happens with both hot and cold water makes me think it’s worth getting the water tested properly for copper and other metals, rather than relying only on the city’s general water quality checks.
Your multimeter readings are useful information, but measuring DC voltage alone won’t rule out an electrical grounding or bonding problem. I’d have a qualified electrician check the grounding and bonding, especially around the water pipes and gas line, and get a plumber to inspect the plumbing system for signs of corrosion or incompatible materials.
In the meantime, I wouldn’t assume the water is safe to drink just because the softener and chlorine levels are fine. I’d contact the local water authority or an accredited lab to arrange a copper test, and use an alternative safe water source for drinking and preparing baby formula until you have the results and proper advice.
Since the house is only seven years old, I’d also check whether the plumbing is still covered by a builder’s warranty. Hopefully, testing will help narrow it down without too much guesswork. With a baby on the way, it’s definitely worth getting this checked sooner rather than later.
10/24/2026 4:30 AM
Hi Jennifer, As the Water engineer said the softener is working I presume you live in a high limescale area where you need a water softener. Do you have to add salt to a plastic tub ?
Are your water pipes made of copper or a mixture like some copper and some iron for example.?
What you need is a simple test kit (any decent Hardware store) to check the PH level in your water, if you have a low PH value, the water will attack the copper piping and you will get blue / green stains.
Also you can do a simple taste test, fill a glass with cold water first thing in the morning, does the water have a metallic taste ?
Is the house yours or do you rent ?
Reply to Forum Thread 16 comments
anicholas (1); Anonymous Poster (4); Doorman (1); Duane Tilden (2); JRaef (1); kevinm (1); Noelkem (1); NotUrOrdinaryJoe (1); old salt (1); PWSlack (1); RobFrew (1); The Wizard (1)
