Previous in Forum: Max. Temp That PVC Pipe Can Endure?   Next in Forum: Cutting Rollers
14 comments
ACME Thread Callout
01/26/2010 6:53 AM
I need help with an ACME thread callout on a drawing. We are purchasing two locknuts for a bearing application and the vendor lists the thread as a major diameter, the number of threads per inch 5 and class ACME 3G. The two dimensions are 15.745 and 13.339 inches. What is the correct thread callout that I need to put on the drawings for the mating threaded shafts for each of these? I don't have a chart that goes that large of diameter and could not find anything in my searches. The vendor was no more help than their current documentation. I may guess at the one and make it 15 3/4-5 ACME 3G (not sure and want to be accurate) but the other seems odd.
Pathfinder Tags: ACME thread thread callout
Re: ACME Thread Callout
01/26/2010 10:38 AM
I'm thinking an Acme thread callout for such an odd size thread would need to be detailed out on paper, with all the dimensions needed to manufacture it.
Mr.Ron from South Ms.
01/26/2010 9:12 PM
At 5 TPI, the thread depth for ACME will be around 0.1" (ie 0.2" on diameter)
That doesnot come anywhere between the two dimensions you have mentioned (or are they different? ) 15.745-13.339
If they are different, then probably you can go as per basic ACME designations-
The Thread OD is 15.745, all other dimensions can be calculated based on the standard 5 TPI ACME.
Good Answers: 97
01/27/2010 1:48 AM
pitch= 1/tpi
Major dia=nominal dia
pitch dia= major - (pitch*.5)
minor dia= major - pitch
addendum= pitch*.25
tooth thickness= pitch*.5
lead= pitch*number of starts
depth= pitch*.5
helix= pitch dia*3.14159/lead (this is the cotangent of the angle)
to calculate the width of the crest or root you need the pcd & minor dia allowances for the required fit.
The minor dia tolerance's are:
For 10 threads per inch and coarser (minus .020")
For finer threads per inch (minus .010")
The pcd allowances are as follows where 'A' =sqrt of the nominal dia:
2G fit= A*.008
3G fit= A*.006
4G fit= A*.004
5G fit= no allowance
The width of the flat at the root of the thread=
(.3707*pitch)- (.259*(minor allowance-pcd allowance))
The flat at the crest of the thread=
.3707*pitch-(.259*pcd allowance)
01/27/2010 8:14 AM
I appreciate all of the detailed information given. These are valuable to the guys in the machine shop actually cutting the threads. What I have are two different locknut applications, each different sizes. What I am wanting to know is what to put on my drawing pointing to the threaded area. In other thread types one calls out a nominal dimension like 1/2-13 UNC. For the nut that is 15.745 major diameter ACME 3G is it actually shown deatailed as 15.745-5 ACME 3G or would it be shown as 16-5 ACME 3G or 15 3/4-5 ACME 3G? And the 13.339 diameter ACME 3G shown as 13 1/2-5 ACME 3G?
Good Answers: 97
01/28/2010 1:33 AM
Call whatever you want but give the machinist the major dia - 15.745 and the tpi - 5 and the fit - 3G and the formula. The formula remains constant regardless of the dia bolt etc..
Good Answers: 204
01/27/2010 12:40 PM
good stuff. GA
01/27/2010 8:09 AM
I am an engineer and I have never heard of a thread "callout." What is a thread callout?? It seems that you have a ACME threaded shaft and you need to manufacture nuts for that shaft. So what is the outside diam. of your shaft?? You speak of 15.745 inches... can this be your shaft diameter?? Must be a very massive shaft. But whatever your case might be, get yourself a 'MACHINERY'S HANDBOOK." Most libraries carry them. The ACME thread form is treated there in great detail, more than sufficient to make nuts. Hope this helps. A. Berlin P.Eng (Ret)
01/27/2010 8:33 AM
Mr. Berlin;
You're an engineer, but you've never even heard of a thread callout? Did you never, ever touch any fastening hardware during your entire career? The thread callout is how you specify exactly what fastener you would like used for a particular application. I learned about thread callouts when I was still in high school, before I had any formal schooling in engineering. To say you're an engineer who has never heard of such a thing is quite remarkable!
Good Answers: 204
01/27/2010 12:39 PM
You could probably find more information in the ASME spec. B1.5-1997(R2009)
Chris
01/27/2010 3:58 PM
Does ASME B1.5-1997(R2009) have a thread chart in it that go up 16 inch diameter?
Good Answers: 204
01/28/2010 2:15 AM
I don't have that one.. so I provided a link. It is the nature of these specs that if your business demands compliance to a spec, you have to buy it. but a google search turns up lots of info, and even software to show you all the parameters.
Chris
01/28/2010 8:16 AM
Thanks Chris. I have a copy of the spec today. It's about 115 pages and I will be reading it today. I will post more as I learn more.
Good Answers: 97
01/28/2010 12:59 PM
This information may assist:
acme thread calculator http://www.americanmachinist.com/Calculators/ThreadCutting.aspx
http://www.tribology-abc.com/calculators/e3_7.htm
Study Guide to understanding "Machinery's Handbook" http://courses.cvcc.vccs.edu/MAC_Stewart/
Need the dimensional data for ACME threads? Here's a great tool. http://icrank.com/cgi-bin/pageman/pageout.cgi?path=/data/acme/acme.htm&t=2
Download ThreadPal 1.0 free trial http://www.softpedia.com/get/Science-CAD/ME-ThreadPal.shtml
Cheers!
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
03/12/2011 4:04 PM
For those interested in ACME threads and Plastic Tooling stories - we had a discussion on "ACME threads and Diamond Dust" at "Skippy and Buzz" -
http://skippyandbuzz.blogspot.com/2010/04/of-acme-threads-and-diamond-dust.html
Good Luck -
Jim
Register to Reply 14 comments
Alexander M. Berlin (1); Anonymous Poster (2); bwire (3); chrisg288 (3); eagertask (1); ronseto (1); Rotag1 (3)
