Previous in Forum: Technical Notes on Tubes   Next in Forum: bpvc
Selection of Threaded Tube Flange
01/27/2010 11:32 PM
i want to select Threaded Flange for 1" SS tube at 10bar HP air Pressure. if i want to design a Threaded Flange (with a threaded stubend which ll be coupled with a threaded tube), then what should i do?
how can i design any flange? (generally we select flange on Pressure-Temp rating). what calculation i need to do
Thanks
Re: Selection of Threaded Tube Flange
01/27/2010 11:50 PM
http://www.mcmaster.com/#stainless-steel-pipe-flanges/=5kd7es
Tube is not usually threaded (though it could be if wall thickness is enough); pipe is often threaded. Your username baffles me.
01/28/2010 2:05 AM
thanks for the reply
Since i deal in Piping so i adopted this name
01/28/2010 3:08 AM
Recognise that flanges aren't usually designed from scratch; they are looked-up in tables, then.
Register to Reply 3 comments
piping_engineer (1); PWSlack (1); Tornado (1)
