Previous in Forum: Making Aluminum Parts Non-Conductive   Next in Forum: Nitrogen Gas Pressure
LTCS Material Application
01/28/2010 11:58 PM
Dear Guys,
pls ,any body clarify my query , what is applicationon of LTCS(LOW TEMP CARBON STEEL)material.is it A 333 ,Gr.6 ?
Re: LTCS material application
01/29/2010 8:32 AM
Yes, A333 grade 6 is suitable to low temp applications. It is indeed a really good one, usually used on seamless pipes, good strengh, good toughness. What is its application? Your imagination - and the standards you are subject to - are the limit. Please, formulate better your question to get further help.
Humm... suspicious you are...
Re: LTCS Material Application
01/29/2010 11:23 PM
A333Gr6, also called "Yoloy" from Youngstown Steel Co., is basically a nickel-enriched carbon steel, giving it high notch toughness (Charpy test values). This suits it to low temperature applications (refrigeration, Arctic/Antarctic installations) where brittleness might be an issue. A285GrC is relatively good at low temperatures, but not as low as with A333Gr6.
Welding electrodes and procedures may differ from the more usual carbon steels.
