Previous in Forum: VFD   Next in Forum: Voltage Conversion
generator
02/14/2010 10:24 AM
i am using 80kva cater pillar make generator . Is earhting is compulsory. if yes then what the wire material & lenght & earthing material i have to used.
jyk
Re: genarator
02/14/2010 12:03 PM
It is essential to earth the neutral and the body of the DG set for personnel's safety.U may use suitably sized GI strip for earthing the same.
regards
Good Answers: 140
Re: generator
02/14/2010 11:46 PM
Yet again... no where enough data to answer this question.
Is this genset the only power source or is there a utility feed also?
Good Answers: 15
Re: generator
02/15/2010 12:37 AM
Count me as 3 out of 3, Yes - You Should ! Use a wire sizing chart, calculate w/the Distance from points A to B, Voltage/Amps & then select your ground rod & wire just for that unit - & always apart from other power inputs ground location ( Keep the soil damp ). Use Copper Wire !
Good Luck,
Joe Woodall, Managing Partner
Georgia Adobe Rammed Earth & Renewable Energy
http://www.georgiaadobe.com
Re: generator
02/15/2010 10:49 AM
pl tell me where i can get that chart...
regards
jyk
Re: generator
02/15/2010 7:07 AM
→ British Standard 7671.
Re: generator
02/15/2010 8:03 AM
It depends on your local regulations which should be followed to avoid bureaucratic interference.
Otherwise there are pros and cons regarding this matter. Read the following link.
file:///L:/electronics/Motors%20&%20generators/Groundiing%20Regulations/TGN-W-05%20Earthing%20of%20mobile%20generating%20sets.pdf
Garth
Register to Reply 6 comments
Anonymous Poster (1); garth (1); Georgia Adobe (1); North of 60 (1); PWSlack (1); ravipra01 (1)
