Previous in Forum: Motor Poles and Maximum Efficiency   Next in Forum: IS Codes for Electrical Panel Boards
Un-Identical Units for One Power Plant Possible?
02/16/2010 10:28 PM
What will happen if we design un-identical units for the hydro power station, Say, one big unit and two smaller units?? I could be wrong, but I have never heard of or seen such case. Is there such case?? If so, please do give me some pros and cons on it. I could think of following:
1. It will be expensive to have two smaller units in place of one big unit.
2. The smaller units might not be capable of generating during low flow (lean season) if the bigger units go out of service.
3. Extra design work.
4. Smaller units are easy to transport.
Give me more inputs, please.
"If opportunity doesnot knock, build a door."
Re: un-identical units for one power plant possible?
02/16/2010 11:18 PM
For matching generating capacity to varying loads, it may be useful to have one or two units sized at about half the capacity of the others. That way, if the load increases a little, you can bring on a smaller unit rather than a larger one.
Every case is different. If there are, say, a dozen turbines, they might well all be the same size. (Each additional unit = 8.33% of total capacity). But if there were only four turbines, each additional unit would be 25% of total capacity, which might be more than you need to add at any one time.
02/16/2010 11:44 PM
Hi Tornado, thank you so much.
What if we don't have variation in load? And our main aim is to make optimum use of discharge in the river? I mean try to generate to maximum and 10% additional capacity in summer when we have more water in the river and vice versa in winter. How will that effect having un-identical unit?
02/17/2010 12:45 AM
I think this situation would be analogous to the previous one. Instead of matching your output to load demands, you would be matching to the "run of the river." If this match needs to be within say 10%, then one or two units should be not more than 10% of the total capacity of the entire set.
And then I am curious: how do the loads (consumers) collectively match themselves to the total hydro station output?
(I am not a hydro plant designer; just asking some common-sense systems-type questions. There are some CR4 threads on hydro plants, and maybe there will be some input from those guys....)
02/18/2010 3:02 AM
Thanks , Tornado.
In my country, Power sector is still at its infancy stage of restructuring. So there is no such thing as competitive electricity market. The consumer ( esp. industries) have to cut down their consumption during lean season when the generation is low.
Register to Reply 4 comments
