Previous in Forum: 220-V 50-Cycle Synchronus Motors Running on 110-V 60-Cycle   Next in Forum: Buried Tank Design
N/C Thermal Switch
02/19/2010 10:24 AM
Does anyone know where I can find a N/C thermal switch that will open between 800°F - 1000°F?
My application is this: (Country: US, Mid-Central)
I have a control (PCB) that turns On/Off outputs to either an AC electric heater or a LP gas burner to heat a small boiler tube (approximately 1" tube). I have the ability to connect a thermal switch to this control. When connected, the thermal switch will be in series with the voltage supply (12Vdc) to the AC heater and LP gas burner relay coils (Tyco T77V1D10-09), providing an electrical interlock so all system heat sources are disabled in the event the thermal switch opens. I need to mount this thermal switch either directly to the tube or maybe on a plate welded to the tube.
The switch cannot not be mechanically resetable. It could be a "one shot" or one that automatically resets at some lower temperature.
Any help would be greatly appreciated.
Re: Project Engineer
02/19/2010 11:12 AM
1) By N/C you mean 'normally closed' ?? If yes, then say so. Not all know what N/C is. 2) Consult Thomas Directory.
02/19/2010 11:25 AM
In the same way that a piece of sisal string is tied across the back of the boiler so as to shut the gas supply valve if it burns through due to a blow-back, perhaps a piece of wire of appropriate melting point with an electrical current passing through it? If the wire melts, then the circuit is cut off, a bit like the thermal equivalent of the electrical fuse?
Good Answers: 58
Re: N/C Thermal Switch
02/19/2010 9:33 PM
Aren't there soldering iron controls that operate in this temp range? A search of bi-metal controls should come up with some candidates. Kilns have hi-temp controls.
mike k
02/20/2010 1:04 AM
If there are no simple thermostats for this temperature range, you could go to a thermocouple inputting to a simple process controller, with whatever relay logic you might need.
I would also check if "Klixon" has a basicswitchin this range.
02/20/2010 1:37 PM
there is a type of thermal switch, made in any heat range. they are known, i believe as ptc switches. They are made from ceramic material, impregnated with metal. As the ceramic heats and expands, the electrical flow is disrupted. As they cool off, the electric flow is restored. some ceramic heaters and 12 volt car defogers/heaters use them to create heat. Running 12 vdc through the element heats it up. when it reaches its operating temp, it expands enough to stop the power flow, maintaining a set temp output.
"god gave us fuel, greed gave us gas"
ageniusforhire (1); Alexander M. Berlin (1); mike k (1); PWSlack (1); Tornado (1)
