Previous in Forum: Low cost Gyro stabilization   Next in Forum: Metal for HCL
fin design
02/20/2010 10:19 PM
how to improve effectiveness and efficiency of the fins used in heat engines?
Re: fin design
02/20/2010 10:27 PM
Increase their surface area.
Good Answers: 49
Re: fin design
02/20/2010 10:50 PM
I assume that you are talking about fins to reject heat from cylinder walls, etc. since you referred to "heat engines". If the engine is not moving, add a fan to increase airflow over the fins. It has the same effect as increasing fin area by about 500%.
If the fins are vertical (horizontal cylinder) you can also install a "chimney" by building a device similar to a funnel (but rectangular- with a "long" neck) over the fins to create a constant airflow with hot "exhaust" that will constantly pull in the cooling air and maintain adequate velocity to improve heat transfer.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Re: fin design
02/20/2010 10:55 PM
Paint them black.
Blow air over them.
If increasing their surface area by increasing their number, there will come a trade-off of diminishing air circulation between closer-spaced fins.
Good Answers: 143
Re: fin design
02/21/2010 8:42 AM
Here's a fun applet intended for electronics heat sink, but you can learn a lot pretty easily.
Re: fin design
02/23/2010 7:20 AM
Forced ventilation helps.
energygod (1); lyn (1); PWSlack (1); Tornado (1); TVP45 (1)
