Recently I have been working on heat pumps and find some heat storage and slow release may be an advantage to stop the tubes frosting up.
I found an article on clay ovens suggesting that certain proportions have to be maintained to avoid smoke pouring out into the space around and maintain the heat in the oven for long periods of time (possibly governed by the amount of clay used also).
Does anybody have any information about the shape of the oven i.e. spherical, parabolic etc. that is necessary for the best performance. As I would assume the shape must be important as the heat would radiate from the source to the surface and converge at a focal point defined by the shape. Second issue is the air flow - how the air travels from the inlet to the fire source and flow modified by the thermal geography of the shape and time of heating up. Again the size of the oven must be important especially how small can it be made and still allow combustion.
I find it fascinating that over more than 5000 years the general shape is still used in many countries however there is no generally available data.
