Previous in Forum: Glow Plug Location   Next in Forum: APC 5000 UPS
queries
03/03/2010 6:27 PM
can 50hz transformer work at 60hz power supply.......?
Engineering Fields - Electrical Engineering - Ron Nombri Engineering Fields - Energy Engineering - Ron Nombri Engineering Fields - Power Engineering - Eternal Power Papua New Guinea - Member - Ron Nombri
Re: queries
03/03/2010 7:59 PM
You may need a 60Hz variable frequency controlling equipment to reduce the frequency to 50Hz or lower before connecting it to the 50Hz transformer. It would be an impedance mismatch to connect a 50Hz transformer directly (without any frequency control interface) to a power supply source of 60Hz.
Kind regards, Ron
Good Answers: 244
Re: queries
03/03/2010 8:02 PM
See the recent discussion about this topic: http://cr4.globalspec.com/thread/50946
- MS
Re: queries
03/03/2010 8:27 PM
MS; You've explained the topic well in your thread. http://cr4.globalspec.com/thread/50946.
Kind regards, Ron
Re: queries
03/03/2010 8:14 PM
The transformer itself will work just fine. The standard low frequency power transformers are not all that fussy about slightly higher frequency applications. It will likely pick up a few percent of efficiency gain along the way. As long as the amp rating is respected it doesn't care all that much about the frequency unless you get way higher.
msamad (1); Ron Nombri (2); tcmtech (1)
