I have installed an air pressure regulator/filter, to my compressor in preparation to do some paint spraying.
When I set the pressure, eg 50/60 PSI, then operate the trigger on the gun, the air pressure falls away, I first used a 6mm air hose, but when this didnt work, I was advised to try with a 10mm hose, again with the same result!!
The cutout pressure on the compressor is 120 PSI. During the trial, the back up pressure in the tank remained constant, so it's not a problem of insufficient air supply.
Does anyone have any ideas ??
Norm.
