Previous in Forum: Adhering bronze to bronze   Next in Forum: Electrolysis of CO2
10 comments
Water Pipe Fittings - Materials and Corrosion
03/14/2010 11:15 PM
In water pipe fittings will a combination of a chromium coated brass fitting to stainless steel fitting accelerate corrosion?
Re: Corrosion -cromium coated brass to Stainless steel fitting
03/15/2010 4:04 AM
Chromium coated brass and stainless steel (austenitic) are very close in the galvanic series. You should define the type of stainless steel, and be aware that galvanic corrosion is also a function of the area ratio of the two metals in contact and the type of fluid (seawater, fresh water..)
corrosion & rust protection
03/15/2010 11:15 PM
The stainless steel is 303. thanks
Good Answers: 141
03/16/2010 12:17 AM
lynlynch is close, a schedule 20 will last longer, and a 309 even more and the best a 316L I hope the chlorine content is not too high. But I expect more of PVC or CPVC.
Plenty of room here
Good Answers: 141
Re: Water Pipe Fittings - Materials and Corrosion
03/15/2010 10:58 PM
What kind of water do you want to run through the system? Or around the system. What is the environment?
Plenty of room here
03/15/2010 11:12 PM
Drinking water (pH=7.5-8.0) supplied by a municipality run through the pipe. Pipe is above ground and iside a chamber. thanks
03/15/2010 11:30 PM
Yes. your pipes will fail in 35 years. Plan ahead!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Good Answers: 141
03/16/2010 12:22 AM
Tip: if it is just a line, you'll be trouble free to switch at the end of your 303 to PVC (cold) or CPVC pipe for 3 to 4 feet and then connect to your chrome piece.
Plenty of room here
03/16/2010 3:54 AM
The corrosion resistance of SS 303 is lower than that of SS 304, so you've to be carefull and consider the chloride content. the "safe" limit for a SS 304 is around 200 ppm...
http://www.azom.com/details.asp?ArticleID=964
S
Good Answers: 109
03/16/2010 10:45 AM
Galvanic cell Is a name applied to corrosion of two different metals in contact with each other and joined by a salt bridge. The water characteristics are important as are the types of metals used and will help to determine how corrosive the water will be on the metals in contact. Generally the chrome is plated to brass but is not in direct contact with the water. Therefore only the brass and stainless steel are in contact. Strider6 has given you links to different metals and they show the nobility of the metals. We are usually only concerned if the metals are far removed on the scales indicated and the electrical potential is at its greatest. Brass is an alloy of copper and zinc and is usually already de-zinced if used in water. Look for the symbols CR or ZRC stamped on the brass as these symbols will indicate corrosion resistant.
Of equal or more importance are the characteristics of the water or electrolyte the metals are in contact. The municipality can provide more information than just the pH. You should get enough information to allow you to calculate the water's capability to corrode fittings and is called Langlier Index. This scale is derived from Alkalinity (as CaCO3), Hardness (as CaCO3), Temperature °C, and pH measured. You will need to calculate this index at the different temperatures (usually hottest, coldest, and average expected) and combine it with the variable pH. With the calculations tabled, you should be able to have an indication of the level of corrosion to be expected at various times of the year or water quality. An index less than 0 will be corrosive and the lower or more negative, the more corrosive the water. Generally, cold water and low pH is more corrosive (low index) than hot and high pH. I have commonly used an index of -0.5 to +0.5 as acceptable for most use, with -1.0 indices or lower getting very corrosive. How far you can deviate the index from will ultimately depend on final use.
Corrosion will also be affected by oxygen and chlorine, but if you have selected good materials this corrosion should be minimized and the fittings and stainless will last a long time.
Some nuisance bacteria of iron and sulphur can speed up corrosion rates as can the presence of hydrogen sulphide.
Treatment for corrosive potential is often treated by the addition of polyphosphate or PP. It is sometimes added by the municipality so you may want to check with them. PP provides a protective monomer coating to plumbing but must be constantly maintained and fed into the system at 1-2 ppm.
Hope this helps.
Langlier's Index
Langlier calculator
04/23/2025 9:22 AM
Use WRC-approved materials.
Simplesζ.
Register to Reply 10 comments
Adrian Mark (2); dvmdsc (3); kevinm (1); lyn (1); PWSlack (1); strider6 (2)
You might be interested in: Tube Fittings, Hose Fittings, Pipe Fittings
