Previous in Forum: Measuring Closing Time and Tripping Time of Breaker   Next in Forum: Designing Capacitor Bank
26 comments
Good Answers: 117
Microwave Ovens
03/22/2010 4:18 AM
Something that I've pondered for a while, why when I place a ceramic bowl into a standard domestic 750w microwave oven does the bowl come out hotter than the food in the bowl, in this case, chilli?
Yet the same bowl (the chilli has been consumed and the bowl washed) after heating porridge oats and milk is cool to the touch and the food is hot after the same amount of time of 2 minutes.
I understand that there are dishes that are not considered "microwave oven friendly", but why, when the same dish, containing different foods demonstrate totally opposite characteristics?
Is this bowl suitable for the microwave oven, not sure! How can you tell?
Re: Microwave ovens
03/22/2010 5:55 AM
Might it have something to do with the amount and the type of material in the bowl?
Good Answers: 117
Re: Microwave ovens
03/22/2010 6:04 AM
Hi PW
checked the weight of the bowl in question with another one that does not get hot, not a lot of difference between the weights, but the material could be different, I grant you that, but how does ceramic material differ to the point where some bowls get hot, other don't?
Re: Microwave ovens
03/22/2010 6:10 AM
...the amount and the type of material in the bowl.
Good Answers: 117
Re: Microwave ovens
03/22/2010 6:17 AM
opps, lost the instructions for the Mark 1 eyeball there for a moment, and not using the glasses.
It could be the food, I'll try with a bowl that up to now has not shown any signs of heating up other than from the heat of the food within, I'll let you know
Re: Microwave ovens
03/22/2010 6:33 AM
Try 100ml of water at ambient and 100L of, say, butter at ambient in the same type of bowl for the same time. What happens?
Good Answers: 22
Re: Microwave ovens
03/23/2010 5:15 AM
Well thanks. I put 100 litres of butter into the microwave as you suggested. What a bloody mess!
Re: Microwave ovens
03/29/2010 2:36 PM
I agree RobertOz, but I did notice that after some length of time and the water content boiled off, the remaining Butter Fat did lubricate all moving parts, re: fan motors and carousel, which took care of the P.M. in the near future.
Good Answers: 73
Re: Microwave Ovens
03/22/2010 8:46 AM
Some ceramics have small amounts of iron. Generally a microwave oven spins the water molecules around creating heat through friction. However when enough metals are included in the ceramics (or the glaze) they will be heated as well.
I would expect that the ratio of water to metal would be responsible for the heating effects you observe.
10
Re: Microwave Ovens
03/22/2010 10:00 AM
Its all a factor of heat transfer and the available methods. (This may get lengthy. )
First let me consider how a microwave oven transfers energy. There's a good reason that microwave cooking happens in what is called an oven. The standing wave radio frequency energy becomes a relatively uniformly distributed inside the resonant cavity that is the cooking chamber. So just like a radiant heat oven, the energy outside of the food enters the food with a relatively even distribution in all directions to the center of the food. In the conventional oven this gets transferred to the food surface by convection from the air around the food and by radiation. In a microwave the radio frequency energy must first get converted to thermal energy. The radio frequency chosen for microwaving is the frequency that vibrates the dipole moment of water. (For now I'll ignore the bowl material.) But despite the uniform energy in the cavity, in the food the energy is not uniform because power is getting transferred. So more power gets transferred to the outer layer of food than deeper inside the food.
Now that the radio energy has been non-uniformly transferred to thermal energy in the food, the same rules of how this energy gets distributed through out the remainder of the food. In the case of your porridge, the oats are not initially cooked and thus the starches are not at first binding the water in place. So convection of the heated water will self stir the contents for at least part of the process. In the case of your chili though, the water is not able to flow freely so the original uneven heating still is in effect and the only way to transfer this thermal energy is the much slower process of conduction. Conduction will transfer energy to different types of materials, convection will only transfer energy to other fluids. So all of the water gets the microwave energy in your porridge. In your chili only the chili to a certain depth gets this energy. The heated chili then conducts this energy to all that touches it, the cool chili in the center and the ceramic bowl on the outside.
To prove that this is the effect, take two bowls of unheated chili. Heat one in the normal method that you use of heating it in one microwave heating. Notice or measure the outside bowl temperature. Next heat separately the second bowl of chili for half the time. Take bowl out and stir the chili. Finish heating the second half of the time. I expect you will find that even though the second bowl of chili technically has had a minimal amount of more energy applied (stirring) the outside of this bowl will be cooler than the first.
Now some bowls will be made of some materials that will absorb some of this RF energy and some will reflect this energy in non-uniform effects. The problem with some non-microwave plastic materials is that when heating non-fluid fluids local hot spots can melt or chemically change the plastic material.
Register to Reply Good Answer (Score 10)
Re: Microwave Ovens
03/23/2010 12:45 AM
If you try to heat plain water and the bowl does not heat up more than the water, then the dish is microwave safe.
Different foods cannot alter the behaviour of the dish itself. However, a rational explanation has to be found for the observed behaviour.
In my opinion the chilli (unfamiliar to me) might be a thick or dryish food. The microwave could have created steam bubble pockets between the food and the walls of the dish. Steam transfers heat rapidly (Condensing steam can have up to15000 btu/(hr.sqft.degF)
This can heat up the dish walls more than with a food that is watery.
bioramani
Re: Microwave Ovens
03/23/2010 2:46 AM
I use a small Pyrex round glass bowl to cook my egg in the morning- rain water is added & a egg broken into bowl- on high for 40 sec- then 20 sec on high- inspect- usually another 15 sec- perfect poached egg- water is hot- outer of glass bowl is just as hot. reason for stopping @ 40 sec- if carried on say not 40 but say 75 sec- usually is explosion inside glass bowl- which I put down to steam pocket under egg erupting & blowing egg all over inside of oven!. Pyrex is considered safe for all forms of cooking- whereas plastic is not- heat can leach chemicals from plastic into food. Earthenware I don't know about- would depend on materials in mix I would say. In my case I would say that the water is transferring heat thru the glass bowl- after all we all know that nothing is a perfect insulator- that is why beer in a cold bottle, removed from the fridge, soon heats up to ambient temp( in a warm climate of course!).
Good Answers: 94
Re: Microwave Ovens
03/23/2010 5:55 AM
I regularly warm ceramic plates by microwaving them for 1 minute at 800W, nothing else in the oven & the plates come out just hot enough to hold without burning my fingers. Obviously the plates are absorbing the microwave energy, whether this is due to iron or moisture I don't know.
The effect brich has noted may be down to the thermal conductivity of the food being heated.
Re: Microwave Ovens
03/23/2010 6:09 AM
The surface of the bowl may have some contribution to the heating effect.
Some surfaces are smooth and do not hold moisture and if these were exposed to the microwave energy the material may not get hot (assuming the material itself does not respond to the energy supplied). On the other hand if the surface is like unglazed pottery where the moisture is difficult to remove - this will end up getting hot because the water (in form of trapped moisture) is being heated up.
It would be a good experiment to try - use the dish as you normally use it without any food in it and heat it in the microwave and then do the same by drying it in conventional oven and then trying it in the microwave see which gets hotter.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Microwave Ovens
03/23/2010 8:10 AM
We have some "melamine" bowls and plates that are not recommended for microwave use. Kids have mistakenly used them before, and they do get hotter than the contents, and would probably crack/explode if taken to an extreme. Perhaps the bowl that is heating up is melamine?
Tom
Re: Microwave Ovens
03/23/2010 10:16 AM
And even the best quality of china-ware having decorations may heat & damage the Oven.
Good Answers: 117
Re: Microwave Ovens
03/23/2010 10:34 AM
Hi all
I have tried the following with the following results
Bowl One, the one that gets hot, in the microwave with a cup of water in the bowl, bowl and water came out after 2 mins, bowl hotter than the water.
Bowl Two, (same size and volume) the one that does not get hot, same volume of water & same time, result water hot and the bowl is warm, I guess the bowl is warm from the increase temp of the water.
I have also tried it with the chilli and the same result, the bowl is to hot to touch, I have also noticed now I'm studying the effects, that Bowl One boils the chilli where the chilli is in contact with the inner surface of the bowl
I know that both bowls are ceramic as I've broken enough of them over the years.
Thanks to redfred for the detailed explanation of how a microwave works, I do understand the principals, I have tried your suggestion of stirring the chilli in Bowl One half way through the heating time, same result, the bowl get hot, the chili boils at where it contacts the bowl.
Bioramani, chilli is a minced meat dish cooked in tomatos and chilli peppers with other spices, much like a curry and has a thick consistency.
So it would seem that Bowl One is not microwave oven friendly, but why does it get hot?
ps, the butter idea...... makes great gee!
Good Answers: 94
Re: Microwave Ovens
03/23/2010 10:46 AM
Try heating the bowls with nothing in for, say, 20 or 30s. This may tell you if all the heat comes from the food or if some is from the bowl absorbing RF energy.
Good Answers: 117
Re: Microwave Ovens
03/23/2010 10:52 AM
tried it, after 15 seconds with Bowl One with nothing in it, way to hot to touch!
Re: Microwave Ovens
03/23/2010 11:07 AM
Well, there's your answer. Seems that bowl is NOT microwave safe!
Tom
Good Answers: 117
Re: Microwave Ovens
03/23/2010 11:48 AM
Yep I know that but why does it get hot or have I missed something?
A previous answer stated that it might be something to do with iron content, how do you tell?
Or is it just a fact that after all the tests, boiled chili, singed fingers and enough boiled water to make tea for a football team do we just accept that some bowls you just don't use without a logical reason why you should not? Not forgetting the melted butter!!
Whatever the reason is, thank you to all who did make a contribution... and if anyone wants butter gee... ask RobertOz!
Re: Microwave Ovens
03/23/2010 12:31 PM
Well, the short answer is that there is some material in the composition of the bowl, that absorbs the microwave energy, whereas a bowl that is "microwave safe" is made up of materials that are microwave transparent, so all the energy goes into the food. As far as the physics of the material goes, you would have to know the complete makeup of the material to figure out who the "offender" is.
Tom
Good Answers: 150
Re: Microwave Ovens
03/23/2010 1:43 PM
Brich, two things come to mind, either or both may be in play here. Yes the iron/metal content of the ceramic may be one of them, moisture absorption is the other. some ceramics/glazes are more prone to absorb moisture than others. That moisture will preferentially absorb the microwave radiation and get hot, same with the metal content of the ceramic/glaze. Ceramic glazes are often colored by metallic oxides. blue is colored with cobalt for instance, reds are often iron oxide.
The way to tell would require a spectrographic analysis of the two bowls. but of course that may be rather expensive.....
Who is John Galt?
Good Answers: 117
Re: Microwave Ovens
03/23/2010 2:05 PM
Hi Rorschach and Tom
Thanks for the answers, now I know why.... but I still don't have a possilbe answer or suggestion as to why the result is different when heating difference foods.
By the by, the bowl in question is blue in color!! Bowl Two is white
Spectrographic analysis or new microwave friendly bowls?
Ikea here I come!
Re: Microwave Ovens
03/23/2010 2:09 PM
Your answer as to why bowl 1 can absorb microwave energy and not bowl 2 is buried in my earlier post. Just as water absorbs microwave energy because it has a dipole moment, some molecule in the structure of bowl 1 must have a dipole moment. Now what that molecule is, who knows.
Re: Microwave Ovens
03/23/2010 10:14 AM
Regards. In my view and have noticed these effects:
The containers [if Microwave safe] only get hot if the contents are of denser & the material takes time to get hot.
As chillies are not dense so in time you need to heat it absorbs very little heat.
Try by putting come curry & see.
And of course ingredient only absorb heat if are not "Microwave Friendly" Friendly will not heat.
Re: Microwave Ovens
03/23/2010 8:25 PM
Could the wording of your question contain part of the answer? You merely mention taking the chili out of the microwave; one must assume it was being cooked from room temperature, possible out of tin at room temperature...or, likewise, from fresh "assembled" (where meat has been precooked/seared/sauteed?). OTOH, your porridge (oatmeal) and milk was "heated" (re-heated?)...presumably from fridge temperature...where either the milk, or milk and porridge in the case of leftover reheating, had been kept prior to "heating," [per-se], or cooking.
Consider also, much of the energy generated in the milk or water used to cook the porridge escapes increasingly as vapor; plus, the maximum instantaneously heat the porridge can develop is water (or salted water) boiling point. On the other hand, fatty/oily foods like chili have no such limitation on temperature, and do not give up heat at boiling point of water. Since, in the case of chili, heat is not so readily released (as vapor) into the oven's ventilation system (and, hence, into the surroundings), it is "more available" for release into the bowl...continuing until the time which there is less food heat to be sunk by the bowl. Summarizing, in one case the heat enters the bowl, in the other case, it enters the air.
As to "microwave safe" (bowl) material ... yes, of course. After all, the kiln from which the bowl came imparted heat at orders of magnitude more than cooking chili or porridge. BTW, even microwave speciality dishes get hot...again, comparatively hotter with oily foods (just like ceramics); but microwave dishes are not very suitable for greasy/fatty foods...so ceramics/glass/etc are completely suitable. Just keep the oven mitts handy.
Register to Reply 26 comments
Anonymous Poster (2); bioramani (1); brich (6); ddhanjal (1); Haajee (2); Neil Kwyrer (1); Nigh (2); NotUrOrdinaryJoe (1); PWSlack (3); redfred (2); RobertOz (1); Rorschach (1); tdesmit (3)
