Previous in Forum: Fouling Factor for Air Cooled Chillers   Next in Forum: Low Hydrogen Consumables
9 comments
Why are Flanges the Weakest Part of a Piping System?
03/23/2010 12:26 PM
Can someone please explain to me why does everyone say that flanges are the weakest part of the pipeline? Because the flange is usually so much thicker than the pipe, so why are the flanges weaker than pipes?
Re: Why are flanges the weakest part of the piping system?
03/23/2010 12:36 PM
The strength of the bolts?
Re: Why are Flanges the Weakest Part of a Piping System?
03/23/2010 1:31 PM
Leverage.
The rest of the pipe is uniform, only at the flanges can the pressure exert pressure on two directions, radially and linearly.
That is why they are built so bulky and have so many bolts.
Drew
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
03/23/2010 1:32 PM
"Weak" doesn't necessarily always refer to "strength".
In this case, flanges are the weakest link because they constitute a number of variables that must be present for joint integrity. These include:
  • proper design (!)
  • proper material
  • proper surface conditions
  • proper gasket
  • proper bolt
  • proper bolt load
  • proper assembly method
  • proper QA
Best regards, HeviiGuy
03/23/2010 2:18 PM
consider also that straight pipe is in pure tension under pressure loading (hoop stress and longitudinal stress), but flanges see a lot of 'awkward' bending as well.
Good Answers: 61
03/23/2010 3:19 PM
It has less to do with the consideration of "Brute Strength" than it does with the greater probability of where the system will spring a leak.
- The pipe itself almost never springs a leak unless it is very old pipe and has experienced a lot of corrosion.
- The butt-weld fittings also have a low probability of springing leaks.
- The flange itself is also less likely to fail.
It is not the flanges themselves. However the "flanged joint" made up of two flanges, a gasket and a bunch of bolts offer the greater probability of leaking. Think of those bolts as your two hands trying to push the flanges together tight enough to hold in the fluid or gas in the system. It is a tough job and one that the flanges, gasket and bolts are designed for and have been doing well for a very long time.
However, relatively speaking, the flanged joint is still the weakest link in any piping system.
Do it once and do it right
03/24/2010 3:18 AM
flange are also "more susceptible" to some forms of corrosion, like crevice or external corrosion, galvanic corrosion and some areas like the seal areas sometime are made in corrosion resistant alloy to avoid leaks.
S
corrosion & rust protection
03/24/2010 9:15 AM
I think weak could be referring to the fact that there is gasket material in a flange. The gasket material will blow out or fail typically well before solid welded joints. If your refering to the structural integrity then gasket failure will not apply.
03/24/2010 4:22 PM
Who told you that flanges are the weakest part of a piping system?
Every component in piping system including the flanges, are well designed like the pipe itself. The only risk in flanges may be due to misalignment (bad assembly), or bad tightening of the stud bolts, or damage of the gasket which can cause a leakage.
03/09/2013 11:54 PM
Dear Friend,
The design of the FLANGES are well taken care, for any piping work, be it STEAM/SUPER HEATED STEAM, High Pressure Air or Water etc.
The allignment of the Flanges, in terms of CONCENTRIC TO THE PIPE CENTRE LINE IS MOST IMPORTANT aspect, and CORRECT DRILLING OF HOLES in terms PCD is also equally important. In other words, Flange FACE OUT and RUN OUT is to bgiven due IMPORTANCE and the pair of flange holes drilling is to adapted, and not individually drilled unless it is done by CNC machines
Refer the posting by Mr. Galala (Post No.8) who expressed "WHO TOLD THE FLANGE JOINT IS WEAKEST IN THE PIPING" - I concur with his Expression/View. If Codes and Standards are correctly followed, every thing IS STRONG and NOTHING IS WEAK.
DHAYANDHAN.S
Abdel Halim Galala (1); Anonymous Poster (1); BoltIntegrity (1); dhayanandhan (1); DonC (1); Drew K (1); PennPiper (1); PWSlack (1); strider6 (1)
