Hi,
16" dia. – 871.873 km long cross country Crude Pipeline from pumping station PS-01 to terminal TS-01 at 871.873 km including intermediate pumping stations PS-02 at 228.6 km, PS-03 at 448.18 km and PS-04 at 666.991 km. We have carried out transient surge analysis of the pipeline to determine maximum pressure rise in the pipeline in event of spurious valve closure/ intermediate pumping station tripping and shutdown of upstream pumping station on secondary protection i.e. station high discharge pressure if primary protection fails.
The surge analysis revealed that the pipeline thicknesses at different locations are not sufficient against the pressure developed during surge. Therefore, there is a need of surge relief valve on 21 locations of pipeline on the upstream of mainline valves to release the surge pressure. Also, as per our client requirement the discharge of this surge relief valve should be connected to the downstream of mainline valve to avoid any pit or installation at that location.
We are enclosing a Load Case for your better understanding in which block valve which is located at 10.346 km downstream of pumping station PS-01, the operating pressure at this location is 1250 psig and flow is 11200 Mtons/day. Thickness of the pipe is 0.312" and the derated MASP of pipe is 1326 psig and valve closure time is 17 seconds. On instantaneous closure of this mainline valve; surge pressure of 1346 psig is induced on the upstream of the mainline valve which ultimately fails the pipeline thickness. In order to reduce the surge pressure up to safe limit, a pressure relieve valve (PRV) will be installed on a 4 inch bypass line across the mainline valve and the liquid released from PRV will be inducted into the downstream of the mainline valve.
Can we connect the discharge of PRV into the downstream of the blocked valve???????
