Previous in Forum: Looking for Information/Materials Sources for Moulding Rubber in a Small Shop   Next in Forum: Looking for information/material sources for making polyurethane foam
Vapor or Gas Problem
02/07/2007 8:55 AM
We have gas or vapors coming thru dip brazing or welding in a tank. Can someone tell me a paint, finish or sealent that would eliminate the problem?
Ray Richard Operations/Sales
Re: Vapor or Gas Problem
02/07/2007 11:21 AM
Motor vehicle underbody seal is loaded with bitumen...
Roof repair mastic can be used to cure leaks in wooden boats below the waterline and without lifting the boat from the water...
What sort of gas at what temperature and pressure?
02/08/2007 8:29 AM
The entrepreneur won't give me the info "confidential" but it is a type of antifreeze used to cool down electronics.
02/09/2007 7:01 AM
You can get a liquid sealant used to seal fuel tanks from the inside. It works with petrol, if the coolant is glycol or ethanol based it should be ok with that as well. We cool electronics down to -40°C & have no leak problems using soldered copper heat exchangers.
02/09/2007 11:59 AM
Thanks, could you recommend a name or brand on the sealent.
I agree copper is a better way to go than aluminum.
Register to Reply 4 comments
Anonymous Poster (1); PWSlack (1); rrichard (2)
