Previous in Forum: Transmission Line Stiffness   Next in Forum: VFD vs. Soft Starter (Pump Application)
Current for a 3ph compressor?
03/30/2010 5:14 PM
I would like to know the formula for working out the current for a 3ph compressor rated at 45kw?
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Current for a 3ph compressor?
03/30/2010 7:07 PM
Personally, I wouldn't worry too much about the formular for the compressor as it does not use electricity.
The motor on the other hand will not need a formular either, it has a special device on it will all the information you need on it. It's call a specification Plate.
Regards,
Sapper
It's all about the Boom! - MythBusters
Good Answers: 804
03/30/2010 9:19 PM
Formula for current in a 3 phase motor:
I = P/(E x Eff. x PF x 1.732)
I = Current
P = Power, 45kW in your case
E = Voltage, you didn't say
Eff. = Motor nameplate Efficiency, assume 80% (.80) if you don't know
PF = Power Factor at Full Load, assume 70% (.70) if you don't know
1.732 = Sq. Rt of 3, because it is a 3 phase motor (I'm assuming, because 45kW is typically too big to run on single phase).
So assuming you have not yet received your compressor and are attempting to determine in advance what size service you will need for it (which moves us beyond the earlier sarcasm), assuming you have a 400V motor and service;
I = 45kW / (400 x .8 x .7 x 1.732)
I = 45000 / 387.97
I = 116A FLC
What your compressor actually draws will likely be less than this, but you must base your design criteria for service equipment on this in advance to be safe.
