Previous in Forum: Pressure Relief Valve   Next in Forum: Is Long Weldneck Flange Considered as a Standard Flange?
Outer Diameter of Pipe
04/03/2010 6:28 AM
Thanks for the responses over the captioned subject.I am also aware that by knowing thw flow and velocity we can find only th ID of the pipe.
I have received a piping calc from our vendor, in the sheet they have first calculated the OD of the pipe and the thickness of the pipe was calculated from the ASME B31.1
tm=PD/2(SE+PY)+A where D is the outer dia.
How they are fixing the OD first and calculated thickness.?
Good Answers: 97
Re: Outer Diameter of Pipe
04/03/2010 9:30 AM
It is normal for sales to work on nominal sizes and class. The calculations are done for them by computer program or friction chart actually working on ID.
04/03/2010 12:01 PM
They are fixing the OD because that is the way to do it (standard available pipe).
By all means, if you want to perform a different calculation and come up with a 9" NPS pipe (9.5" OD?) go ahead. (Good luck getting any fittings that will match up to that custom pipe: flanges, elbows, tee's, .... )
Register to Reply 2 comments
