Previous in Forum: 120vac with 24v in a gutter   Next in Forum: Avery Labels for Custom Electronic Words?
12 comments
Good Answers: 114
Infrared Video
04/08/2010 12:21 PM
I would like to put some IR leds on an object & be able to take video of the object in motion
I'm hoping to use the IR as invisible points of reference.
the video would then appear to be normal, unless the IR reveal mode was turned on
I would like to use a nice common format like avi so I could transmit with an email...
Suggestions?
Questions?
Good Answers: 60
Re: Infrared Video
04/08/2010 1:13 PM
most ccd cameras see infra red but the mommy or daddy of them all is Sony they use a ccd chip thats very sensitive and you can use the camera in night-shot mode.
the camera has its own IR illumination built in which you can turn off if required
any good ?
Good Answers: 114
Re: Infrared Video
04/08/2010 10:39 PM
you're right about the cameras
the software is the issue then...
The project is being able to evaluate different mountain bike suspension set ups, along with this the position & techniques of the rider.
there are reasons to keep a lot of the evaluation data private from the personnel at the test sites.
Good Answers: 60
Re: Infrared Video
04/09/2010 1:12 AM
please clarify what you want software to do?
Good Answers: 213
Re: Infrared Video
04/08/2010 11:13 PM
Have a look at the iPod Nano- yeah, it is supposed to be a music player, but according to Apple website information, it offers an "infrared" mode for the video capture...I haven't tried it, but am intrigued, since it is orders of magnitude cheaper than a typical infrared camera...
Re: Infrared Video
04/09/2010 1:13 AM
No way to separate the data post camera. You probably need two cameras and you may have to put an IR cut filter on the one you allow others to see. Keep the output of the other one private, just use the eyepiece and don't enable the screen.
Re: Infrared Video
04/09/2010 5:23 AM
GA: I'm guessing that you'd need to physically clamp the two cameras together.
Re: Infrared Video
04/09/2010 8:56 AM
Can you use red LEDs and just track them? I have messed around with roborealm vision and it does a great job of blob separation and tracking.
Good Answers: 213
Re: Infrared Video
04/09/2010 9:51 AM
If the iPod nano really works the way they say it does on the Apple website, you can accomplish this with a single "camera".
Good Answers: 114
Re: Infrared Video
04/09/2010 11:55 AM
I was going for the whole 9 yards
I could then have anyone shoot the video.
& the analysis done remotely.
I really only need 10-20 frames, but it's easier to pick the right frames from 100's
I can open a single frame with photoshop[gimp] on a grid & see the relationship, which is what we've been doing.
I'm trying to take it to the next level of precision, without letting on exactly what the key factors are
I was thinking about regular old red led's, but the lighting gets trickier, bright sun, making them invisible. laser pointers being too directional.
I'm looking for 3-5 points, that will be distinct from 20-30 meters, The points being no more than 1 meter apart.
of course the budget is zero, until we can provide proof of concept
Good Answers: 60
Re: Infrared Video
04/09/2010 11:58 AM
WELL after much though i think i have a solution.
you need two small ccd cameras one set up for infra red and one normal.
now you could either strap them together side by side or one on top of the other.
Or one looking straight ahead and one looking down at a piece of plain glass set at 45 degrees, This will allow one camera to look ahead through the glass i would suggest this one to be the normal one as the glass will filter out some of the infra red. And one looking down would see the reflected image off the glass at 45 degrees this one would be the infra red one.
you the need a piece of security recording kit like the one i have that will record up to four channels simultaneously onto a laptop, With the option of encoding some of the pictures.
the encoded ones would need the code to unscramble them.
whilst the other video channel could be left unscrambled.
this way anyone could do the recording but all they would see is the normal picture.
Only you with the decrypt key would be able to view the other one.
How about that?
Good Answers: 60
Re: Infrared Video
04/09/2010 12:07 PM
http://digitalvisiongb.com/PC-CCTV.php
CCD Bird Box Camera with Night Vision 420TV lines & High Quality Image
Tiny camera perfect as a bird box / nest box camera.
CCD 420TV line chip for enhanced crystal clear image.
10 Infra-red (IR) LEDS for close range night vision.
Short range night vision to reduce nest box glare.
Also great as a baby monitor or nanny cam system
SONY CCD Security CCTV Camera - 20m Infrared Night Vision & 420TV Line
Vivid colour 420tv lines for excellent definition.
High resolution SONY CCD chip for great images.
20m Infra red night vision in complete darkness.
360 degree wall mount for versatile positioning.
Robust waterproof case and lens guard.
4 Channel Output Wireless CCTV Shop Camera System with Quad Processor
Wireless quad view CCTV security system.
Full colour day and BW night view wireless cameras.
Compact robust design with 5-7m night vision range.
Remote control to switch between cameras.
Zoom function & motion detection feature.
£177.87
£209.00
inc VAT
£40.00
£47.00
inc VAT
Good Answers: 60
Re: Infrared Video
04/09/2010 12:15 PM
or you could place one of these cameras ontop of the normal camera this would aid the tester to set up the view and see what both cameras would be lookig at but only see what is on the normal camera.
now the one fetured in the link could be set up to dial you and send the infra red pictures direct to a remote recording system.
then you will know whats happeing in real time and if reqyuire could ring the tester up and ask for a different test to be carried out.
How cool is that, Remote covert testing?
Register to Reply 12 comments
Anonymous Poster (1); cwarner7_11 (2); Garthh (2); peterg7lyq (5); Randall (1); rcapper (1)
