Previous in Forum: No-load losses   Next in Forum: switchgear desing
India - Member - New Member
reverse power trip of diesel generator
04/09/2010 10:44 AM
three gen. were running together ,suddenely one gen. trip along with indication revers power failure. so i wanted to know what are the possible resion of reverse power failure of one gen. while running three gen. in parralle?
what are the solution to avoid reverse power failure of gen.
Re: reverse power trip of diesel generator
04/09/2010 11:08 AM
There are several possibilities. If the voltage regulation settings are not matched, or a regulator malfunctions, reverse power will occur to the lower-regulated genset. A fuel delivery problem to one genset, such as clogged fuel filter, will cause it to run slower, and it will then receive reverse power. Similarly, a governor malfunction or incorrect setting could also cause one genset to run slower.
Some preventive measures include careful matching of all settings, consistent upkeep of fuel filters, and prevention of air leaks into the fuel system.
04/09/2010 11:31 AM
Well
My first thought is the gen that tripped had a different voltage/impedance than the others which in turn the other gen's start supplying power to the lower voltage one.
guest
04/09/2010 11:12 PM
if the avr and governor are working ok and fuel is intact reverse powers is very very rare
Better not count the cent if the risk is many many dollars.
Good Answers: 150
04/09/2010 12:57 PM
There are a lot of people on power trips these days....;-b
Sorry, couldn't help myself...
I'll go now....
Who is John Galt?
Register to Reply 4 comments
Jans (1); Rorschach (1); thanksinadvance (1); Tornado (1)
