Previous in Forum: Isopropyl esters   Next in Forum: Industrial Desulfering of Natural Coal
Flange Face Chamber
04/09/2010 8:58 PM
Apply into the flange face chamber a wooden dummy in order to protect the flange face; one can also leave the original gasket in place.
What is "flange face chamber" here?
I am not a home work cheater. I am a translator seeking professional help
Re: Flange Face Chamber
04/09/2010 11:43 PM
Hi wingman1985,
I haven't a clue. If you would provide a portion of the text in which this term appears, we would have a better chance of knowing by the context.
Mike
Good Answers: 61
04/10/2010 10:15 AM
Just a guess, but this may be nothing more than a mix-up in translation
In Pipe Fabrication, before the "Spools" are shipped all flange faces were fitted with a plastic or wood "Flange Cover" to protect the gasket face from damage.
Do it once and do it right
04/10/2010 10:52 AM
I would guess similarly. If you took a valve or spool out of a pipeline, it would be a good idea to protect the exposed flange faces of the remaining pipe. I suspect the word "chamber" is a weak choice. "Space" sounds better.
Register to Reply 3 comments
Mikerho (1); PennPiper (1); Tornado (1)
