Previous in Forum: Briggs & Straton White Smoke   Next in Forum: Fuel Cell or Diesel Gen Set?
8 comments
Is the "Equation Of Time" the Only Difference Between Solar and Star Movement?
04/11/2010 2:31 PM
"The sun is a star and it travels round the equatorial axis just like the rest of the stars, It just happens to blind out the light of all the others. The only difference is that it is sufficiently close so that changes in the earths speed in its orbit affects its position in the sky slightly." The figure of 8 thingy that people sometimes call the equation of time.
So is that the only difference in the apparent movement of the sun and stars or do the stars also get affected by the slight change in earth speed due to the slightly elliptical orbit of the earth?
thanks
Brian
Pathfinder Tags: astronomy solar power
Re: Is the "equation of time" the only difference between solar and star movement?
04/11/2010 3:36 PM
In principle, the eccentricity of earth's orbit would affect the apparent rotation of the star field, but the orbit is so small in comparison to stellar distance that this would scarcely be measurable.
The sun is close enough for this to make a difference. The figure-eight "analemma" shows how the day varies depending on where the earth is in its orbit. In particular, it shows the apparent lead/lag of sunrise/sunset at various times of the year. It factors into celestial navigation, but my course in that is so long ago that I have forgotten the details.
Now I gotta look up the Wiki on "analemma"....
04/11/2010 6:07 PM
Thank you for the very quick reply and the word "analemma" I just couldn't remember it.
Brian
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
04/12/2010 8:10 AM
So have most cartographers over the past 30 yrs. One just doesn't see it on new maps anymore.
Prophet Freddy has the answer!
Re: Is the "Equation Of Time" the Only Difference Between Solar and Star Movement?
04/12/2010 2:32 AM
You are generally right.
http://www.astro.cornell.edu/academics/courses/astro201/sidereal.htm
If the time period is long the movement of the axis of the earth itself(precession of equinox) introduces a parallax shift to the star field. The pole star was not always the pole star.
http://csep10.phys.utk.edu/astr161/lect/time/precession.html
The sunitself moves along in space. This also factors in if the period is long.
http://hypertextbook.com/facts/2002/StacyLeong.shtml
bioramani
04/12/2010 3:14 AM
The earth circles the sun so I guess that the speed that it moves across the sky seasonally is different than the speed that the stars move across the sky. Just the writing down and asking the question helps me visualize it! The answers are a bonus. Thanks
04/12/2010 9:49 PM
And I finally "got" that due to its proximity, the sun goes up and down on the celestial sphere over the seasons but the stars do not.
Good Answers: 27
04/13/2010 5:50 AM
The Earth's axial tilt varies between 22.1° and 24.5° (but see below), with a 42,000 year period, and at present, the tilt is decreasing. In addition to this steady decrease, there are also much smaller short term (18.6 years) variations, that is also affected by Sun's gravitation in its depleting angle relative to Earth's, known as nutation....from wiki
What this means is that the celestial north and south poles have never been exactly pinpointed nor an astronomical time constant established without daily re-calculation. Navigators using sextants always tried to factor in where the sun should be at a precise time on the following day. Any discrepancy needed to be averaged to maintain course.
04/13/2010 8:15 AM
Hello
1. Equation of time has nothing to do with precession (change in the direction of tilt of earth axis, as well as change in earths tilt angle. If I am correct, it is the equation to count the effect of varying rotational speed of earth around Sun. The earth rotates around Sun in elliptical orbit. It rotates fast when it is closest to Sun around 3rd July and slowest when it is far away from Sun around 3rd January. I will elaborate this in couple of days. ext two days, I may be too busy to put these details in simple language.
2. The precession period is not 42000 years. It is 26000 years. This means that the direction of pole of the earth is now towards pole star. This direction goes on changing. It changes slowly. In few more thousand years, our ancestors will see some different star as pole star (such as Vega). But after 26000 years, again human beings (if they maintain this earth and are alive) will see same pole star what we See now.
Register to Reply 8 comments
bioramani (1); Duckinthepond (2); gaiatechnician (3); gsuhas (1); Tornado (1)
