Previous in Forum: GE Fanuc Programming Software   Next in Forum: Solution for Power Supply Switch Circuit
Cable Size
04/12/2010 9:23 PM
What will happen when we will a under size cable for a job to rnu a motor through a soft starter?
Re: Cable Size
04/12/2010 10:31 PM
Don't try this at home--or in your industrial plant either. The cable is likely to overheat. This may conduct heat into circuit breakers or fuses, leading to premature tripping. Or it may melt the cable insulation, leading to ground faults, short circuits, or fires. Or it might melt your soft starter, requiring you to buy a new one. You may also violate the 3% voltage drop criterion, if the cable is significantly long.
Re: Cable Size
04/14/2010 7:40 AM
Something will overheat, melt, go bang, start a fire, hurt or kill someone, etc., etc., and then the person that specified it and the person that installed it may find themselves persued from various legal angles for compensation and/or prosecution.
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
