Previous in Forum: Power Cable Comparison   Next in Forum: Vacuum Tube
1 Pole Reclosing in 2nd Zone
04/14/2010 2:14 PM
HI,
AT HV POWER TRANSMISSION LINES, 1 POLE RECLOSING IN 1st ZONE FAULTS ....IT IS OK.
BUT IN 2nd ZONE 1 PHASE GROUND FAULTS ?
WHAT DO YOU THINK ? IS IT FEASIBLE SOMETHING ? AND IS AIDED RECIEVE NECESSARILY ?
THANKS
Re: 1 POLE RECLOSING IN 2nd ZONE
04/14/2010 3:25 PM
It sounds like you have a phase to ground fault (unless this is a sensing problem and the fault isn't actually real). If reclosing into the fault did not remove it then it is 'permanent' and you will need to send a line crew in to find and repair the fault (which could be a tree on the line or a downed line on the ground). Follow standard company procedures, etc.
If you want any better advice you are going to need to provide much more information presented in a clear and detailed way, for example what does Zone mean (phase, location, upstream/downstream line segment designation), etc.
No I would say line fault location and repair is necessary.
04/15/2010 2:56 AM
Please turn off Caps Lock, for pity's sake....
04/15/2010 12:56 PM
Single pole single shot auto re-closing is generally adopted for a section of transmission line between two stations.Generally 80% of length of line is covered under First Zone.the balance 20% is covered under IInd Zone.
[Suppose a single phase to ground fault occurs in the end 20% of line. Then one end will Trip in Ist Zone and other end shall trip after second zone delay.
[However provisions such as Carrier aided under reaching tripping schemes are available to make the other end also trip in zone 1 time. This enables the successful auto re-closing feasible without minding for synchronising before re-closing .
For any other fault Single pole auto reclosing cannot be attempted .
There is nothing either good or bad, only thinking make it so -
Re: 1 Pole Reclosing in 2nd Zone
04/15/2010 1:23 PM
you can put into use high speed single pole single shot even if there are no channel recieving and sending.
am i right ?
04/16/2010 1:06 AM
Can be Possible, but the dead time has to be increased by 400-500ms ( i.e second zone time) to ensure that both end had cleared the fault.
It is not advisable to operate the system in an unbalanced condition ( Keeping 1 pole in open condition) and not generally practiced.
Anonymous Poster (1); jack of all trades (1); Panneer Selvam (2); PWSlack (1)
