I have run into a situation where I need to install a 8" DIP water main in contact with a 48" RCP storm drain. Has anyone ever dealt with this situation? Is there some type of HDPE or rubber pad I can install between the two? I can not go under the storm drains because of other utilities and can not go around because of wetlands. The alignment can not be shifted. A long time ago, I saw a similar situation, and the old time engineer cut a section of an old tire, wrapped it around the pipe, and laid it on top of the storm drain. This may be my only option. There is only 30" of material to the surface above the storm drains. Any help is appreciate.
