Previous in Forum: how is the stress analysis of a filament wound shell   Next in Forum: Cleaning Lime Deposits on Air Cooled Condensers
10 comments
Filament Wound Shell
04/17/2010 9:09 AM
You are right, but in filament winding we don't have any layer also we have a texture of filament in a/-a directions and by one stage winding we don't have a layer. For example we must have several winding time depending on angle and band width.
Good Answers: 247
Re: Filament Wound Shell
04/17/2010 12:52 PM
Thanks for sharing.
04/17/2010 1:16 PM
This is for you. You guys can work as a team.
Under Home Treasures
Good Answers: 247
04/17/2010 1:44 PM
This is what makes CR4 so valuable... taking two great ideas and combining them into one game changer: filament-wound basements.
"Worried about those tornadoes under your home? Wrapper Dapper will encase your basement in military grade carbon fiber. Got secrets under there? We can add Kevlar to make your basement immune to bullets and pry bars."
04/17/2010 2:14 PM
LMAO! "I beat the draft" could be the catchword. They'd sell like hot cakes in rural Idaho, Texas and AZ. You might want to offer metal screening for the "roof" to keep electronic eavesdroppers from monitoring your signals. Oh, and a tin foil hat for every member of the family!
True synergy in action.
04/17/2010 9:04 PM
ROFPML ha ha haaaa!!!!
04/17/2010 4:37 PM
There might be an interesting problem here. If the filaments were wound predominantly circumferentially, what would protect the vessel from longitudinal stresses? The manufacturers have probably figured this out. Either longitudinal or helical fibers could solve this. The phrase "a/-a directions" perhaps addresses this, but it is too vague to tell.
Good Answers: 247
04/17/2010 6:11 PM
That's the beauty of filament winding for tubes, pressure vessels, etc. The filaments are oriented to best accept the stresses. Once the epoxy cures they can accept both tension and compressive loads. Makes for very light, strong structures.
Good Answers: 247
04/17/2010 6:32 PM
Other handy features include not being locked into integer numbers of plies, the ability to form compond curves easily, the ability to fully automate the layup process, and very little resin waste.
04/17/2010 6:41 PM
If the cylindrical axis is taken as angle zero, and the wrapping angle as θ, the fibers would resist longitudinal stress per cos θ, and circumferential stress per sin θ. Just add them all up, plus maybe a smidge for the glue.
04/17/2010 7:47 PM
or how about referring to an established code/standard?
A couple examples (of numerous):
ASME RTP-1
ASME BPVC Section X
BS EN 13923:2005
Register to Reply 10 comments
Anonymous Poster (1); Blink (4); lyn (2); Mikerho (1); Tornado (2)
