Previous in Forum: Steam Turbine Power Flactuating   Next in Forum: Two Hydraulic Cylinders to be Synchronized
10 comments
Dry Ice
04/24/2010 8:18 AM
Is the amount off dry ice enough in the container to cool 48 kg steel from 80 °C to 20 °C?
Container is W=0.8 m (0.58) Depth 0.6m (0.37) H= 1.05 m (0.69) (inside dimensions)
I have to open the container 16 times on 12 hours
0.4W/m2/°C
density of dry ice 1.2-1.6 kg/dm3
Specific heat 0.8kJ/kg/°C
Pathfinder Tags: dry ice cooling
Re: dry ice
04/24/2010 5:52 PM
I am trying to see where the amount of dry ice is specified....
If the container is completely full, where do you put the steel to cool it?
Re: dry ice
04/25/2010 7:13 AM
I can put 3 steel bars in the container on an holder.
There is 100mm of empty space in the container at the beginning.
Max amount of dry ice 5,8x3,7x5.9 dm =126dm3x1.3kg/dm3=163 kg
Good Answers: 143
Re: dry ice
04/24/2010 7:30 PM
Why in the world would you use dry ice for this? Cold water, lad, cold water.
Re: dry ice
05/02/2010 1:11 PM
Can you cool with water till - 30°C
Good Answers: 143
Re: dry ice
05/02/2010 1:15 PM
Your post said "20 °C".
Re: dry ice
05/03/2010 3:34 AM
It is -30°C
Good Answers: 143
Re: dry ice
05/03/2010 6:34 AM
Good luck with your homework, but try to get the numbers right next time.
Re: dry ice
04/25/2010 12:52 AM
Your post has abundant information. However, it is not connected in a logical manner.
How intimate is the dry ice in contact to the precious cargo?
What the hell are you trying to do?
Re: Dry Ice
12/08/2023 7:36 AM
...and why?
Why is <...Max amount of dry ice...163 kg...>?
Re: Dry Ice
12/08/2023 2:52 PM
Register to Reply 10 comments
Emdesign (3); Mikerho (1); PWSlack (1); SolarEagle (1); Tornado (1); TVP45 (3)
