Previous in Forum: Ancient Pyramids Are Machines   Next in Forum: Shock waves from volcano
15 comments
Plastic Grommet Corners
04/25/2010 10:25 AM
Does anyone know of a wholesale or retail source for these Black, plastic/nylon, tarp corner protectors w/ grommet?
An extensive search has found nothing but snap on repair parts and such.
Thank you.
Re: Plastic grommet corners
04/25/2010 11:07 AM
Netmaker,
This may not be exactly what you are looking for, I think these are for sails, (netmaker, sails) hum.........but anyway...............Tack Plate With Rivets
04/25/2010 1:20 PM
Just might work. I'll look into it.
Thank you.
nm
04/25/2010 8:05 PM
at $10.00 per set, I think this is too overkill. Although it would work in a bind if i can not find the lighter weight ones i am looking for.
Thank you.
Good Answers: 15
04/27/2010 6:26 AM
Did you see these at the same place they only cost 4.70 each instead of 10 each.
http://www.sailrite.com/Headboard-Rivets-Nylon-3-x-4
scotchdrnkr
04/27/2010 6:43 AM
missed them the first time.
Thanks.
04/26/2010 11:21 AM
This one with round corners.
Good Answers: 60
04/25/2010 4:53 PM
04/25/2010 5:25 PM
The tarps are made by numerous companies. The corners seem to be very thin but rigid. There is a hole made for a grommet or the entire piece is pressed into the tarp with a grommet machine. I think the rest of the triangle is glued???
Good Answers: 58
04/25/2010 6:11 PM
Check Harbor Freight, they have stuff like that.
mike k
Good Answers: 60
04/25/2010 6:17 PM
04/25/2010 8:03 PM
Same.
You would think it would an easy hardware item to find as a lot of tarp companies use them.......... not so......
Thank you anyway.
06/24/2010 9:36 AM
They would sell wholesale in high volume to the tarp makers and not even think of selling small volume retail. Therefore, why advertise?
04/25/2010 6:33 PM
Good luck. I think you have been derailed.
Re: Plastic Grommet Corners
04/26/2010 5:21 AM
04/26/2010 6:57 AM
still not the item I'm looking for. These corner protectors are for everything else but..... Its got to be out there somewhere. Many tarps have them already.
thank you anyway.
Register to Reply 15 comments
Anonymous Poster (2); lyn (2); mike k (1); Mikerho (1); netmaker (6); peterg7lyq (2); scotchdrnkr (1)
