Previous in Forum: Real Cost Savings On Automotive Filters & Parts   Next in Forum: Manufacturing Power Supply
34 comments
.025mm Specialty Nickel Wire
04/28/2010 5:59 PM
I've acquired 4,824,801 gross meters of Purity Grade 99.87 nickel wire with a diameter of .025mm. I'm looking to sell the wire but have found out is a specialty product. I don't know whom to contact. What industry or companies should I contact. I'm willing to pay a healthy commission to anyone that can sell this for me.
Sincerely,
Douglas Shipley
Senior Partner
Nickel of grade NP-2 is not a nickel alloy, i.e. a doped material, made of systems Ni-Al-X, Ni-X-Al.
The wire is made of nickel of grade NP 2, the chemical composition of which is similar to grades of Ni 99,6 DIN 17740 (Germany) and Nickel 205, Grade A (U.S.).
douglas
Pathfinder Tags: nickel wire
Good Answers: 119
Re: Nickel Wire
04/28/2010 6:15 PM
Various alloys are used in the EDM process. I would start with a google search for "nickel wire EDM".
Re: Nickel Wire
04/28/2010 7:26 PM
Thanks. I've googled nickel wire for several days and reached out to most of the specialty wire manufactures. I'm more interested in contacting the end users.
douglas
Good Answers: 119
Re: Nickel Wire
04/29/2010 4:42 AM
Got that. Wire EDM is an electro-machining/cutting process. Facilities that perform wire EDM are the end-users of the alloy wire. I believe some of them use very large quantities. Do you want to sell the whole batch or 4.8 million 1 meter pieces? I'd bet the former. Either way, good luck.
Re: Nickel Wire
04/29/2010 10:34 AM
EDM, that's the key.... thank you very much.
Good Answers: 119
Re: Nickel Wire
04/30/2010 10:19 AM
Just curious, is your wire really 0.025 mm (~0.001 inch) or is it 0.25 mm (~0.010 inch) diameter?
Re: Nickel Wire
04/30/2010 10:59 AM
Unfortunately, it's .025mm
douglas
Good Answers: 150
Re: Nickel Wire
04/30/2010 11:10 AM
Sounds like it might be used to make screen for industrial filters and such. Most screen manufacturers these days are offshore.
I can only think of one place called Dorstener Wire Technologies here in Spring TX(actually about two miles from my house) that might have an idea of who might could use it.
Who is John Galt?
Re: Nickel Wire
04/30/2010 12:25 PM
Thank you, I'm calling them now.
douglas
Re: .025mm Specialty Nickel Wire
04/28/2010 9:53 PM
The only end users I could think of would be steel or aluminum makers. They use nickel for alloying. Although they use nickel in a different form than wire, they could also use wire. I did a quick calculation and found that amount of nickel wire is equivalent to 4.091 cu meters or 144.468 cu ft or a cube 1.6 meters (5-1/4ft) each side. Thats a pretty good chunk of nickel.
Mr.Ron from South Ms.
04/28/2010 10:40 PM
Thanks Ronseto. I've come to learn that the value of the wire or nickel is that it's been drawn down to .025mm. Albeit a very niche market, therein lies the value.
douglas
Good Answers: 50
04/29/2010 12:40 AM
Have you tried talking to manufactures of flash lamps, xenon, for example. These tubes need a very fine, strong, and conductive wire wrapped around them, on which high voltage is pulsed to start the flash process. One of them might be interested in a deal for trigger-wire.
Good Answers: 120
04/29/2010 10:32 PM
Per Ardua Ad Astra
04/29/2010 11:09 PM
Thank you for your advice
04/30/2010 12:38 PM
Hi, I was wondering if the resistance was high enough, if this wire could be stranded and then woven as a flexible core for a high temperature heating mantle or with a fiberglass or quartz wool over-wrap as a flexible insulated high temperature heater? I think a company like Brisk-Heat, Watlow, or some other large manufacturing entity of flexible heat tapes could possibly be interested in this fine gage of wire.
I can imagine plenty of applications where conformability, high temperature stability, and chemical inertness would be highly desireable features. I realize that Ni-Chrome wire is used for many heating mantles, but Ni-Cr is just one of hundreds, or probably thousands of formulations that can be engineered for the particular "watt-density" necessary for custom application.
Nickle is a very interesting element! Truely an unsung hero in terms of its thermal stability, its ability to "passivate" and also "wear" rather well.
Good Answers: 150
04/30/2010 12:47 PM
Seems like I remember that one of the key parts of automotive airbags was a flame arrestor/heat diffuser that sits between the bag and the explosive charge that was made up of wool made up of fine gauge stainless or nickel wire. You might could use this for manufacturing woven PEM fuel cell electrodes (we used corrugated foamed Nickel 200 when we were playing with them, but nickel 200/205 mesh would probably be workable too.).
Who is John Galt?
04/30/2010 12:56 PM
MRC,
I'm not in the industry, you might say I'm a neophyte .... but I'm learning quickly.
Nominal Composition
Alloy Ni% Mn% Fe% Si% Cu% C% Ti%
Nickel 205 Min 99.6 Max 0.20 Max 0.2 Max 0.10 Max 0.10 Max 0.05 Max 0.05
Nickel 205 LC Min 99.6 Max 0.20 Max 0.2 Max 0.10 Max 0.10 Max 0.02 Max 0.05
Specifications
British Standard Werkstoff Nr UNS Designation
Nickel 205/205 LC - 2.4061 N 02205
douglas
04/29/2010 10:56 PM
Go to the trade association of the Ni industry, www.NIDI.com, and look for a listing of companies that make things from pure Ni.
04/29/2010 11:10 PM
04/29/2010 11:15 PM
How many pounds of material is it?
What country is it located in?
The Thermal Spray Guy
04/30/2010 9:28 AM
I've come to learn that the value of the wire is in the diameter, not the weight.
douglas
10/04/2013 12:39 PM
Hi Douglas,
I am interested to learn how your quest ended up regarding this specialty nickel wire. Please send me a note to sakolo@gmail.com, would be appreciated.
thanks much
Good Answers: 74
04/29/2010 11:24 PM
douglas
That is very thin. One tenth of my high E string on my Guitar. How about you find someone who could weave it, combined with other fibers. Could become a fashion statement, so don't worry about the price.
I know, these bloody artists, wattle they think of next
Good luck and don't worry about the commission, just buy me Missus a hat made from it, Ky.
The Twain Has Met
Good Answers: 150
04/30/2010 8:02 AM
Nickel is a poor choice for jewelry, a lot of people develop allergies to Nickel.
Who is John Galt?
Good Answers: 74
04/30/2010 7:32 PM
Hi Rorschach
It was not meant for jewelry but for weaving in general. Picking fashion was just off the top of my head. More down the lines of this post. 20
I would do a bit more research but don't have the time. Hope Doug finds a use, I'll keep it in mind, Ky.
The Twain Has Met
Location: 20 miles north of Mt. Shasta California along I-5...aka , Yreka, California.
04/30/2010 10:36 PM
I think this wire has an electrical resistance of 1.9 ohms per foot. Mine was used for electrical heater wire in an electric blanket about ten years ago. Also the same wire was used as a heater wire for a hair drier. So it has application in industries producing electrical heaters. Cartridge heaters used in soldering irons and other similar applications. The Thomas Register provides lists of companies that produce these products and thus may use this material. But you know this is like reverse engineering to find a producer that uses the product you have rather than using the material you picked up so cheaply to produce a marketable product. There is opportunity in this.
06/23/2010 2:25 AM
Hi Dougls,
Did you able to sell your wire ? Pl let me know.
08/06/2010 6:48 AM
Hi,
For exchange of experience etc. on this very special Ni-wire 0.025mm, 99.8% material
pls contact
lpi_wyoming@yahoo.com
Thanks
09/16/2010 2:44 PM
Commercial offer
To attention of the Director
Dear Sir,
« Intex-export» Company produces nickel wire of different marks. We can ship big quantities on a regular basis and at a very competive price.
We offer the following marks of nickel wire:
1. DKRNT -0.025 -KT-NP2
2. DKRNT-0.025-KT-NP1
3. DKRNT-0.025-KT-NP0
Wire marking is done in accordance with GOST 2179-75 «Wire from nickel and siliceous nickel. Technical terms». The nickel wire NP2 GOST 2179-75 is similar in its chemical composition to the marks: Ni 99,6 DIN 17740 (Germany) and Nickel 205, Grade A (USA).
Chemical composition of DKRNT-0.025-KT-NP2 is 99.80-99.89%; DKRNT-0.025-KT-NP1 – 99.90-99.98%, DKRNT-0.025-KT-NP0 – 99.99%.
« Intex-export» Company is an International Barter Center's subsidiary production unit. International Barter Center began its operations at the trade and info-communicational market in spring 2009. Aggregating the most worthful offers, International Barter Center functions as a programme and informational guide in the economic environment. The Intex Company has been succesfully selling its suppliers' products for two years already.
More information about the product:
Wire is made of nickel marks NP2, NP1 and NP0. It does not have grease marks, oxidation tints and chalking. The surface is even, clean, without blister, hollows, flaws, scratches, guide marks, lamination and dints.
The wire is spooled to plastic coils which are packed in transparent plastic containers, ensuring safety while storing and transporting. Containers are sealed with 4 (four) Giredmet seals (JUC-TACC OF GIREDMET) « GAC/68».
All products are certified by Test Analytical & Certification Center of Giredmet in accordance with all chemical purity and quality requirements.
Manufacturer's certificates, sampling report, Giredmet chemical composition certificate and Giredmet test certificate (in Russian and English languages) are provided.
In order not to interrupt the working process of customers the goods DKRNT-0.025-KT-NP2 and DKRNT-0.025-KT-NP1 are always available in stock.
The nickel wire purity degree is calulated as the difference between 100% and aggregated composition of bound impurities.
Terms we work on:
- Minimum order – 1 kg;
- Maximum order per month is 100 kg – NP2, 30 kg – NP1, 3 kg – NP0;
- Delivery terms – CIF;
- Payment terms – Letter of Credit.
If you are interested in our offer, please, feel free to contact us at the following email – mail@mtc-intex.com.
We can also be reached by telephone: +7-916-020-77-77
With hope to establish fruitful business relations with your company,
Yours faithfully
Andrey Muratov
IBC «Intex-Export» Company
General director
10/05/2010 7:04 AM
Our company – «Intex-export» LLC – is the manufacturer of nickel wire and we would like to offer you cooperation on shipping this product. We believe that this cooperation will turn very profitable for both your and our companies. First of all, you will not have to overpay to the third parties, since the prices direct from the manufacturer are lower that from distributors and agents. Secondly, we can ship worldwide, on a regular basis and adjust the delivery terms to every single client.
1. DKRNT-0.025-KT-NP2
Wire marking is done in accordance with GOST 2179-75 «Wire from nickel and siliceous nickel. Technical terms». Chemical composition of DKRNT-0.025-KT-NP2 is 99.80-99.89%; DKRNT-0.025-KT-NP1 – 99.90-99.98%, DKRNT-0.025-KT-NP0 – 99.99%.
General terms we work on:
- Maximum order per month is 200 kg – NP2, 30 kg – NP1, 3 kg – NP0;
If you are interested in our offer, just send us an inquiry and we will be glad to discuss the possible ways of our partnership.
Yours faithfully,
Andrey Muratov
General director, «Intex-Export» LLC
CR4 Admin - phone number and email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
11/30/2010 7:19 PM
Call me at 770-895-4385. I am currently attempting to acquire and resell nickel located in Germany. I would love to resell your product if it is still available. Contact me at secureprojectz@gmail.com.
Current Nickel is:
I have Nickel Wire and these are the specs for 91254 meters. Please call 770-895-4385 or email me at secureprojectz@gmail.com if you are interested.
Chet
01/04/2011 5:07 AM
Dear Sirs,
We offer supplies of nickel wire DKRNT-0.025-KT-NP2 and DKRNT-0.025-KT-NP1 on a regular basis. It's produced according to GOST 2179-75 (Russian state standards), which corresponds to Nickel 205, Grade A (ASTM B 162), HS code 75052100, with test certificate of GIREDMET (principal testing center in Russia).
Now, we have 120 kg of DKRNT-0.025-KT-NP2 wire ready for immediate sale. Nickel content: 99.85-99.88%, diameter: 0.025 mm, 1 gram = 227 meters. Price: EUR 3.00/running meter (FCA-Moscow). The price can be discussed depending on the ordering volumes.
Sergey Yatsyk
E-mail: yasa27@ukr.net
01/31/2011 10:24 AM
Our company – «Intex-export» LLC – is the manufacturer of nickel wire and we would like to offer you cooperation on shipping this product. We believe that this cooperation will turn very profitable for both your and our companies. First of all, you will not have to overpay to the third parties, since the prices direct from the manufacturer are lower that from distributors and agents. Secondly, we can ship worldwide, on a regular basis and adjust the delivery terms to every single client. We offer the following marks of nickel wire: 1. DKRNT-0.025-KT-NP2 2. DKRNT-0.025-KT-NP1 Wire marking is done in accordance with GOST 2179-75 «Wire from nickel and siliceous nickel. Technical terms». Chemical composition of DKRNT-0.025-KT-NP2 is 99.80-99.89%; DKRNT-0.025-KT-NP1 – 99.90-99.98%. General terms we work on: - Minimum order – 1 kg; - Maximum order per month is 200 kg – NP2, 30 kg – NP1; - Delivery terms – CIF; - Payment terms – Letter of Credit. If you are interested in our offer, just send us an inquiry and we will be glad to discuss the possible ways of our partnership. With hope to establish fruitful business relations with your company, Yours faithfully, Andrey Muratov General director, «Intex-Export» LLC +7-916-020-77-77 mail@mtc-intex.com skype: mtc-intex
02/28/2011 7:12 PM
Douglas Have you been able to acquire a buyer for your NP-2 wire? Please let me know. You can send a message to me/Doug at platcap@gmail.com thanks
08/07/2011 12:19 PM
Douglas,
Were you able to sell the Ni wire through this forum? I have access to a large quantity (20 million meters) of 0.025 Ni wire (99.8% certified purity) and I also don't know who to contact or what industry/companies I should try. If you can lead me to a buyer, there's something in it for you or your company.
Lou
Register to Reply 34 comments
Anonymous Poster (10); aurizon (1); byalaman (1); cbjtrust (1); douglas (6); E.Dalder (1); ky (2); mjb1962853 (3); mrc109 (1); robertgrist (1); ronseto (1); Rorschach (3); sakolo (1); ThermalSprayGuy (1); vermin (1)
