Previous in Forum: Nylon Evlon Peek   Next in Forum: Gasoline from Carbon Dioxide?
11 comments
Detect and/or Destroy Methanol in Water?
04/28/2010 8:31 PM
Long story short, I've acquired a few thousand feet of plastic pipe that used to have a mixture of methanol and water running through it. The methanol was used as an antifreeze beneath an ice rink (the MSDS states it is pure methanol and nothing else). I realize that the porous plastic pipe will have absorbed small amounts of methanol over the years, which will "leech" into the water. I have two projects in store for this pipe if it is possible... I would like to run this pipe to our corrals and stock tanks so we can get water to horses and cattle. I am also going to build a solar hot water system (the plastic pipe won't flow drinking water; heat exchangers will be used). However, I know methanol is pretty toxic. Since methanol is readily soluble in water, I am hoping I will be able to "flush" the pipe to get the mixture dilute enough to be safe. However, I won't KNOW if it's dilute enough without testing the water somehow. Does anyone know of any way to detect methanol in water?? If I can't easily and readily detect the methanol, what would be a good way to destroy the methanol in the pipe? I would suppose there is SOMETHING that I could flush the pipe with that would destroy the methanol and not leave toxic byproducts in the pipe. Any ideas here?
Re: Detect and/or Destroy Methanol in Water?
04/28/2010 10:56 PM
Maybe you're worried about a storm in a teacup.
Yes, methanol can be dangerous/toxic in sufficient doses, but considder your applications and the original situation.
The original selection of the pipe should have been so that solution of methanol into the pipe materials would have been minimal. If methanol did dissolve into the pipe walls, then you would expect to see the pipe to show levels of degradation (brittleness, discolouration etc) especially on the inside surface. If degradation is not present then it would seem they made a suitable material selection.
Your heat exchanger will probably need to have some form of antifreeze in it to cope with overnight winter conditions. So I'll leave that one for you.
For your stock water, consider this. When I buy a new plastic tank for domestic water use, the manufacturers recommend a "fill once and dump" process in order to remove the manufacturing contaminants inside the tanks. (Release agents and so on) For brand new water pipe, the same is recommended.
Methanol is highly soluable in water. A steady flow of water through your pipes for a day should "attract" any residual methanol into the water, then flush through with compressed air,then water again.
Don't know of any "neutralizing" chemical that doesn't have other challenges. I'd suggest that when you run the water, if you can still smell the methanol, then you need to flush some more.
What other treatment is being applied to the stock water? Do they have open troughs with float valves? How clean are the insides of the tanks and other items? How clean is the water initially?
04/29/2010 1:48 PM
Yep. Dosage is everything.
Soak it for a few days, flush it out and repeat.
There are small amounts of methanol in red wine. Around 200 ppm.
If you are really keen, you can pay a couple of hundred dollars to a lab who do wine analyses and get a methanol analysis done.
But don't get too carried away with the the horror stories on msds sheets. Your horses are unlikely to get exposed to damaging doses. The drinking troughs will be exposed to the air as well, so any traces of methanol will tend to dissipate to the air.
04/30/2010 7:16 PM
I'll probably use automotive antifreeze in the heat exchanger due to availability and cost. The stock water will not be treated in any way, as it is safe rural tap water. The tanks themselves are usually pretty dirty by our water standards, though they're much cleaner than the creeks and ponds that the horses and cattle are used to drinking out of.
04/29/2010 1:21 AM
Solvents diffuse slowly into polymers, and diffuse slowly out again, so you can't get rid of it quickly without destroying the pipe. If you cap the ends of a length of pipe for a few days, and then sniff the air inside, you may or may not smell methanol. If you don't smell it, the pipe is okay. If you can pump air through the pipe, perhaps by leaving a stack of it out in the wind, it might remove more of the methanol. The warmer the temperature, the faster this will happen.
Methanol isn't so toxic that a trace of it will kill your animals. It takes about four ounces to kill or blind a human being, which is a lot compared with other poisons. IT doesn't accumulate in the body either.
Methanol isn't that simple to detect in water, because there are always other organic compounds that will interfere with simple measurements. Normally, compounds like methanol would be absorbed from large volumes of water into beads of a polymer and then separated using gas chromatography, which is time consuming and expensive.
Dangerous Bill
Good Answers: 141
04/29/2010 1:27 AM
The permeation of PVC pipe to methanol is less than 100 ppm per year. Don't worry to much for your project. And if you want to flush it out - go to the hot water temp. specs and pressure flow it out. Methanol will smell in water, but evaporates easy with higher temp.
If you stir the water methanol will decrease foaming.
Plenty of room here
04/29/2010 2:58 AM
Methanol is toxic to most biological systems. Use fresh pipe for the livestock watering project.
Good Answers: 60
04/29/2010 3:32 AM
http://en.wikipedia.org/wiki/Methanol
The lethal dose of pure methanol is estimates to be 1-2 mL/kg (Jacobsen 1986); however, permanent blindness and death have been reported with as little as 0.1 mL/kg (6-10 mL in adults) (ATSDR 1993).
taken from link below
http://www.antizol.com/mpoisono.htm
http://www.physicsforums.com/showthread.php?t=105655
http://safety-council.org/workplace-safety/methanol/
Effects of Methanol Poisoning
As little as four milliliters can cause blindness and 80 to 150 milliliters can be fatal; about half a milliliter per kilogram of weight is deadly.
Drinking methanol causes effects similar to common alcohol, such as an upset stomach and dizziness, with the addition of pronounced vision problems. After these effects disappear, they reappear six to 30 hours later, only with much greater severity. severe symptoms tend to appear 18 to 24 hours after consumption. the relapse time makes it imperative to seek medical help as soon as possible.
The most seriously poisoned lose consciousness and die of respiratory or heart failure. those who do not die may stay in a coma for as long as a week and may be left blinded.
taken from this link http://safety-council.org/workplace-safety/methanol/
http://www.wrongdiagnosis.com/m/methanol_poisoning/intro.htm
How to test for methanol
http://www.google.co.uk/search?q=how+to+test+for++methanol+&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&redir_esc=&ei=8TXZS5-gFJj60wSRmM1R
Good Answers: 60
04/29/2010 3:47 AM
information on methanol
http://www.hpa.org.uk/web/HPAwebFile/HPAweb_C/1194947310643
The Methanol Institute (MI) today released a Methanol Safe Handling Manual to be shared across the global methanol distribution chain to increase awareness of the chemical and promote safe handing in order to protect workers, consumers, and the environment. This manual will be accessible to everyone who comes into contact with methanol, from research engineers to shipping managers, from tank truck drivers to plant operators and will be available throughout the world. The manual will also be a valuable resource for emergency first responders looking for information on the physical properties of methanol and incident management.
Taken from
http://www.biodieselmagazine.com/article.jsp?article_id=3591
04/29/2010 11:57 PM
See if a standard police breathalyzer will detect methanol. They are made to detect ethanol, but may work with both.
Good Answers: 114
04/30/2010 11:13 AM
Yes it will
I used a cheap breathalyzer to determine when biodiesel had been dryed [methanol removed] enough for sale
make sure to but one that doesn't require positive pressure [blowing into it] to detect
the cost is around $30
04/30/2010 7:19 PM
I've found really cheap breathalyzers on the 'net for $4 to $5... Are these generally accurate enough for this basically one-time use?
Anonymous Poster (2); dvmdsc (1); Garthh (1); Just an Engineer (1); LG_Dave (1); morrie (1); peterg7lyq (2); PWSlack (1); wpenrose (1)
