Previous in Forum: Fall Protection Requirements   Next in Forum: Mobile Phone Dangers
PSI Calculation
04/30/2010 11:08 AM
I have a 60' verticle column of water (well) with a 3' pipe coming off the bottom of the column. Within 5' of the pipe exiting the well I have a 2" line coming out vertically (at 90 angle) from the 3' pipe.
Question - how do I determine the PSI coming out of the 2" line?
Re: Determining PSI
04/30/2010 11:16 AM
Measure it. I bought a pressure gauge the other day for about $15.00 that screws onto the hose bib. PSI doesn't "come out of the line". The pressure is measured with no flow.
Or, if this is homework, come clean now.
Re: Determining PSI
04/30/2010 11:23 AM
Measure it.
Measure what? The shut-off head? Simple. Can be calculated as the static head.
Let us suppose you attach a hose to the outlet. And position a pressure gauge at the outlet. What are you measuring? The pressure drop along the hose?
Re: Determining PSI
04/30/2010 11:47 AM
Two inch line is failing and may rupture.
The 2" pipe does have a shut off where it connects to the 3' pipe.
Our concern is if the shut off valve should fail as we break the pipe connections above for repair - what would the results be coming out of the 2" line?
Re: Determining PSI
05/04/2010 3:21 AM
Some water will come out, as determined by the ability of the valve to shut off and the quantity of water behind it.
Re: PSI Calculation
04/30/2010 2:14 PM
Good Answers: 29
Re: PSI Calculation
04/30/2010 3:04 PM
Sixty feey times 0.433 equals 25.98 PSI
Si vis pacem, para bellum
Anonymous Poster (2); lyn (1); morrie (1); peterg7lyq (1); PMoon (1); PWSlack (1)
