Previous in Forum: Water as a Fuel   Next in Forum: Prosthetic Motion Control for Amputees
Single Use Flowmeters
05/02/2010 3:30 AM
I am searching for engineers with experience and/ or a need for single-use flowmeters.
Re: Single use fowmeters
05/02/2010 3:48 AM
Single-use flowmeter?? All of the devices I know of will survive for more than just one flow measurement, and can be used continuously/repeatedly.
05/02/2010 8:16 AM
I was thinking about disposable units due to sanitary reasons; for instance medical applications.
05/02/2010 9:57 AM
Never worked with dispoable flow meters, worked with disposable bioreators so.... What type of flow meter, would that be a rotometer type or venturi type flow meter?
just did a quick google
http://www.powersourcing.com/sf/disposableflowmeters.htm
Good Answers: 183
05/02/2010 10:43 AM
Could you please give the requested answers? It could be much more easy to give you an answer, solutions are available.
Good Answers: 183
05/02/2010 6:30 AM
Do you think about throw away flow meters?
Questions:
- why throw away?
- fluid, temperature, pressure
- uncertainty
- cost level expected
- quantity
If you answer those questions it could be possible (but not sure) to give you an answer. If you do not then no answer for sure.
05/02/2010 8:20 AM
I have experience with single use peak flow meters used to measure human respiratory capacity.
Register to Reply 7 comments
Daan (1); lyn (1); nick name (2); peterg7lyq (1); phoenix911 (1); Tornado (1)
