Previous in Forum: ISO 17025 Calibration Question   Next in Forum: Promass flowmeter 83 accuracy?
17 comments
Steam Flow Measurement for Higher Line Size
05/05/2010 11:39 PM
Dear all,
I have a LP steam line of 46". It is supplying the steam to some plant. Kindly suggest the suitable flow meter except Orifice and annubar.because
I can not use the orifice for such a big line size and annubar can not give a good reading for such application.
Re: Steam flow measurement for Higher line size
05/05/2010 11:48 PM
  • What kind of accuracy do you need?
  • What are your limitations on pressure drop?
  • Is this a new line?
  • Has flow rate never been measured in this line before?
For this size of line, I think that an orifice meter would be one of the cheapest and easiest ways to go.
Anyway, answer my questions and we'll see what we can do.
Pakistan - Member - New Member
05/09/2010 4:46 AM
How do you thing that orifice will work.
AUR
05/09/2010 5:10 PM
Like this:
05/10/2010 12:35 AM
You cannot use Orifice plate for ≥ 12 inch lines.
Annubar for ≥ 36 inch lines.
and this line is 46 inch????????????????????????????
05/17/2010 3:36 AM
Why not!
You can use orifice plate for any size of pipe line. You can calculate the pressure drop against flow rate (and other parameters). The choice depends up on the accuracy expectations.
05/06/2010 1:02 AM
How about a steam flow nozzle:?
http://www.wyattflow.com/pdfs/fnp_techbrief.pdf
05/06/2010 3:09 AM
46" is a "big" pipe. For smaller pipes, vortex-shedding flowmeters can give good results on steam service.
05/06/2010 3:24 AM
that we know, please suggest about 46" line.
Re: Steam Flow Measurement for Higher Line Size
05/07/2010 12:51 AM
Some more data will be needed to suggest anything:
Pressure of the steam
Mass flow rate max and min
What accuracy is expected
05/07/2010 12:52 AM
Dear All,
For 46 inch line size you can use insertion type vortex or turbine flow meter for steam,
No pressure loss
High Accuracy
Regards
Adeeb ur Rehman
05/07/2010 1:00 AM
Insertion type is never accurate. It give local velocity. This need not be average velocity (and most of the time it it will not)
05/08/2010 1:09 AM
better you go for electro magnetic flow meter.
05/08/2010 1:21 AM
Incorrect, sir.
From WIKI:
The magnetic flow meter requires a conducting fluid, for example, water that contains ions, and an electrical insulating pipe surface, for example, a rubber-lined steel tube.
Steam is not a conducting fluid, containing a very low concentration of ions.
05/18/2010 10:43 AM
Electromagnetic flowmeters cannot be made to work on steam, as steam is non-conductive.
05/08/2010 5:14 AM
I would suggest a doppler type velocity meter. With pressure and temperature compensation added to the velocity, a very accurate value can be obtained.
Consult Foxboro,Combustion Engineering,honeywell or other instrument manufacturer for details.There may be other options of which I am not aware, but an instrument manufacturer is the place to go fo advice on your application.
HTRN
05/09/2010 4:43 AM
Dear All,
Please Note that for higher line size you can use INSERTION TYPE VORTEX or INSERTION TYPE TURBINE with an accuracy of ± 1%
Regard's
CR4 Admin - phone number removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
AUR
05/17/2010 6:20 AM
Thank you all,
We have decided to go ahead with Flow nozzle.
Thanks once again for replies.......
Register to Reply 17 comments
adeebulrehman (2); Anonymous Poster (4); gsuhas (3); Mikerho (3); munneykhan (1); prajalpatil (2); PWSlack (2)
