Previous in Forum: Why Fuse is Not Placed in Neutral Wire   Next in Forum: ACADE or Promis.E? High Voltage Substation Design
New Zealand - Member - Kiwi
Good Answers: 29
Motor on SD-Starter Trips Breaker on Startup
05/13/2010 4:35 PM
Hi All,
Had an interesting situation yesterday that I would appreciate some expert opinions on :
The site is a printing factory where a compressor driven by a 30KW 3-phase induction motor is being installed. The motor is started with a star-delta starter. Motor FLA is 57A, and the thermal overload relay is set to 30A (note overload wires inside the delta in a S-D starter setup). The feeder from the switchboard is about 30m long, feeder protection is a 50-63A MCCB with the magnetic trip factory set to 504A.
When the Start button is pressed, the motor starts to spin up for about 2-3 seconds, and then the MCCB trips. A clamp meter around one of the phases reads 350A while the attempted startup is in progress.
My comment to the contractor was that the startup current is too high for a 57A FLA motor starting in star mode, it should be lower than this, around 200A. I suggested that either the unloader valve on the compressor is not working (motor starting under heavy load), or the starter is incorrectly starting in delta.
The contractor is going to install another MCCB today, this one with adjustable thermal and magnetic trips. He believes that if he can stop the breaker tripping, he will have solved the problem.
I think that if he does this, he will be back on site before long to either repair the starter or replace the motor, but he don't need no stinkin' advice from some upstart engineer so all I can do is watch and see what happens.
Thoughts, anyone?
paulusgnome
Re: Motor on SD-Starter Trips Breaker on Startup
05/13/2010 4:47 PM
I assume that someone from your organization will have to sign some sort of acceptance instrument before the contractor will be paid.
If you are that person you can either modify the agreement or just not buy it off until you are happy.
Otherwise, just stand back and watch.
Good luck.
Good Answers: 29
05/13/2010 5:07 PM
To me it's all care no responsibility.
I work for the breaker distributor, we supplied the wholesaler, and the wholesaler supplied the contractor.
The wholesaler is going to flag my concerns up with the contractor again, hopefully he will listen and take the time to check it over again.
But yes, he will be shooting himself in the foot if he fries anything.
paulusgnome
05/13/2010 5:27 PM
I'll leave the technical issues up to the electrical experts, but if you have documented your concerns and the contractor goes ahead with his plan, you will have done all you can.
And your company will have sold another breaker.
Good Answers: 804
05/13/2010 5:44 PM
The current draw in Star can be no more than 33% of the maximum locked rotor current, even if the unloader valve is stuck. So with a nameplate of 57A FLC and assuming 600% LRC, that makes it 342A LRC in Delta. Therefore in Star, the highest current that motor can draw is going to be 113A!
I would say that your assessment is dead on, except to my mind, he has BOTH scenarios going; connected in Delta AND the unloader is stuck. It might not, by the way, be connected improperly, but the starter transition time may be set too low and it is transitioning into Delta almost immediately. I have seen this trick used time and again when technicians don't want to bother finding the REAL problem, otherwise they might have to fix it. Someone had a problem, so they cranked down the timer to essentially force it into Delta and power through it. Just another reason why I hate Star-Delta starting....
By the way, the OL relay setting is a little too low, should be set at 58% of the motor FLA, so 33A. Not likely the cause, but it also might give some nuisance tripping later on.
05/14/2010 3:01 AM
If the FLA is 57, the conductors should be sized for 57 x 1.25 ≈ 71A. I'm rusty on it, but I thought breakers could be even higher.
If the motor draws 114A (= 57 x 6 ÷ 3) for a significant time, no wonder it is tripping the breaker.
I bet the next breaker up from 50-63A is a larger frame size....
Good Answers: 804
05/14/2010 11:14 AM
The motor nameplate FLA is 57A, not 57A x 6 / 3. Don't understand where that came from... The current draw in Delta will be split between the 2 sets of conductors; (hence the 58% setting of the OL relay). You size both sets of conductors based upon the 58% value because even though 58 + 58 would technically be over 100% current, they are out of phase with each other, so each set will carry an amount of current equivalent to 58% of the motor current (not 58% of the load). So each set of conductors is sized based on 33A in this case.
The OP is not in North America (he's in New Zealand). They have different protective device rules than we do. The 125% sizing of the conductors is a US standard (NEC 430.22(C) specifically), no idea if the Kiwis have a similar requirement, but probably.
05/16/2010 11:38 AM
In the RN we calculated start current to be usually around 6-8 X the FLA, so the current you are reading would appear to be about right.
So the main breaker is actuating too soon maybe or the thermal switch is activating. You could try removing the temp sensor in some way and starting once and once only...
The unloader may be at fault too of course, but I doubt it......the measured load sort of fits in my experience.....
Of course there might be a wiring error in delta......
If you look at this link:-
http://en.wikipedia.org/wiki/Induction_motor#Starting_of_induction_motors
You will see that it mentions a start current of between 5 - 9 X the FLA......
Sadly I have been out of that business too long to be of much further help!!
Best of luck.
Register to Reply 7 comments
Andy Germany (1); JRaef (2); lyn (2); Paulusgnome (1); Tornado (1)
