Previous in Forum: Servo valve   Next in Forum: Tie Breaker and ATS Logic
68 comments
Liquid Head Gaskets - Do They Work?
05/15/2010 9:58 PM
Does this work for an engine that leaks water in the oil? When the car stands still, the cooling water goes down 3 inches in the radiator, about the same height where the head gasket sits. No water under the car. But the oil level is growing on the dipstick. I will drain - the water? and the oil, through the oil drain. The engine is difficult to service V6 in town and country. I have read about chemical seals. Who has experience? Do they do the job? What brands are recommendable? How good is the repair and what are the risks? Thanks for sharing your experience.
Good Answers: 145
Re: Liquid head gasket products - do they work? brands
05/16/2010 1:06 AM
I usually ask the following questions when someone wants to bodge a repair on a car.
How long do you want to keep it?
What is it worth to you?
Are you trying to (sell)get rid of it?
How long has it been doing it?
When did you notice it first, did the engine over heat?
While you may have some success with this type of product for a short time if your losing a lot of coolant/water into the sump then you may have other problems. if your head gasket failed through corrossion then its likely to pop some where else.
The concept of how this stuff works is that it blocks the leak but it tends to block other things too. So you'd only want to use it to bodge a repair so you could offload the vehicle to some other poor schmuck.
If you want to keep the vehicle then you'll have to repair it properly.
05/16/2010 3:05 AM
It started last week. Overheated. The idea is to keep it. Only it is very difficult to deal with the gaskets,because under the hood it is full, full and the engine is transversal. I guess it will be the most difficult side as Murphy's Law says. What should be a reasonable time frame for repair? Thank you.
05/16/2010 11:40 PM
if it has started by overheating , means most chances are , your head might be cracked and leaked , it might not be the gasket , it may be the head it self , so think care fully .
now you have to think twice before you take further steps .
Good Answers: 145
05/16/2010 3:19 AM
You would have to refer to someone local to quote the repair.
But it sounds like a TPA sort of job and you will be charged accordingly.
05/16/2010 9:04 PM
I treated myself to quote. The gaskets seem very expensive. Is it normal that there are 3 layers in the gasket. Like 3 different sheets on top of each other. This is the first time I see this. Thanks
05/16/2010 9:30 AM
Alumiseal (disclaimer) has worked for me in the past. Depends where and what has failed.
It's cheap and if it doesn't work, it won't hurt anything.
Good Answers: 60
05/16/2010 3:13 PM
The sealent you put into radiators is called "K seal"
Good Answers: 60
05/16/2010 3:37 PM
Has the oil changed colour ? ie white and creamy ?
Its emulsified,
the reason it does it when engine is still the water is under presure for quite a long time while engine cools down, and as there is no presure in the cylinders the water can now seep into the cylinders
05/16/2010 9:05 PM
Water and oil nicely separated, no foam, no mix. Car was sitting here for a while - now 14 days already. Thanks
05/16/2010 11:43 PM
if the water is not mixing with oil means there are more chances for cracked head .
i am diesel engineer , dealing this kind of problems very often .
ajit
05/18/2010 1:35 PM
If you have water entering the cylinder(s), the engine would hydro-lock, bending connecting rods, breaking pistons, blowing out the head gasket(s). And that's if you can get the engine to turn over one revolution
Re: Liquid Head Gaskets - Do They Work?
05/16/2010 8:57 PM
Hi All,
I really appreciate your help.
After the answer of Tobu I decided to take a closer look. The car didn't start anymore, was blocked like it had no power enough. I have put it over the hole and tapped the oil off. While the car was a little upward, I also saw the exhaust muffler dripping at the lowest point. Seems not tight anymore. I found my gallon of oil back, but first 2 gallon water came out of the oil pan.
It was a nice Sunday afternoon and I have taken the heads off. Just finished. In the cylinders was also water sitting. Dried it out and WD40'd everything. Tomorrow I will have a close look at the parts I removed.
Till now the job was very easy. The two heads have top valves and hydraulic pushers from the middle (V6). I always worry when I have to repair and see timing devices, like chains or belts.
No, piece of cake thusfar.
I will buy a set of head gaskets, a thermostat, 6 spark plugs, oil filter and hope that will do the job. The most difficult was to find to disconnect all the different plugs and connectors.
I just need to know how much torque I need to give and the rank of the 8 head bolts to tighten. Is cleaning the surfaces with a block and sandpaper ok? Thanks for the help again
05/17/2010 12:47 PM
If the engine overheated it's possible that the head is warped. Use a good metal straight edge and check for head flatness over several directions. If you find that their is warpage the head will have to be milled flat. If much of the head has to be milled off you might be better off buying a new head because the intake ports of the head and manifold won't mate properly and the cylinder compression will increase due to the decreased head volume.
05/16/2010 9:01 PM
I forgot to say: I bought the car second hand and it appears that someone did a liquid seal treatment, before selling it to me. All kind of fill is there at places where it should be. Very salty taste.
Good Answers: 145
05/16/2010 9:59 PM
Ok, cleanliness is next to godliness when it comes to mating surfaces, so no, do not sandpaper the head/deck(top of the block)/manifold surfaces. It will cause an uneveness to the surfaces that the gasket may not compensate for.
You can scrape them (using a narrow 25-40mm wide paint scraper or a razor blade) be careful not you gouge any of the surfaces or else they will need to be re machined (if that's possible). Use WD-40, RP-7 or similiar as a "cleaning" agent and to soften up the stuck on gasket remains. You might need to soak the area and leave it to sink in before scraping some more.
Your head gasket will consist of layers of material according to the OEM specification or to enhanced specification of the gasket supplier(assuming a known name brand gasket manufacturer) You should check to see if you have to replace the head bolts. Some engines have one shot headbolts that can only be used once because they stretch under the appropriate torque to provide the necessary tension of the head to the block. Some though not all headgaskets will have some instruction on torque procedure and level. You may be able to google it or go to a forum site for you make/model of vehicle to get the information if a workshop manual is not available.
Do what you can to get as much of the sealing "gunk" out from all the water jackets to prevent future difficulties. You may need to take the radiator out and have it cleaned out by removing one or both tanks and getting the core cleaned out. That's assuming that the core is in "good" condition.
You may need to apply a sealer to the head gasket (some GM motors have this requirement) though its not usual to do it with "Monotorque" brand gaskets. Refer to the service workshop manual for more information on this. Don't be tempted to go overboard with the application of the sealant, you don't want the sealant to be anywhere it shouldn't be.
Handy hint. When you have (successfully) reassembled the motor avoid the temptation to fill the coolant up and drive her away. By all means replace the oil and oil filter (saves brain fade incidents, don't ask me why), but wait overnight to allow the various sealants to cure before putting the coolant back in.
One other thing to check, on both heads and the cylinder walls see if there are any telltales of cracks in the casting, this may show up as a dark thin wiggly line on the machined surfaces or the combustion chamber. If that's the case you have more than the gasket to replace. Also you have to check the heads and the deck for trueness, as both surfaces need to be flat. Or else the gasket will let go again in short order.
Good Answers: 141
05/16/2010 10:10 PM
Thank you Tobu. The head gasket are completely metallic, 3 layers with different geometry. Never saw this before. GA
Plenty of room here
Good Answers: 120
05/16/2010 10:33 PM
head gaskets often have folding spring metal gasket grommets around the cylinders and all passages through the head with a fiber reinforced tough gasket material everywhere else. They used to use a varnish when gaskets were installed, but now they use high temp silicone in addition to the above gaskets with grommets and holes etc.
Areas with low pressure, like the oil pan and valve covers now use silicone sealant that hardens in place. Works quite well,
Per Ardua Ad Astra
Good Answers: 141
05/16/2010 10:41 PM
That is how I know them too. But these are like 3 flat layers (connected) of stainless steel sheet metal, with just a little punch around the cylinders. (Head gasket) Thanks
Plenty of room here
05/16/2010 10:44 PM
Seeing as this engine has overheated, you may be looking at more than a blown head gasket. Pull the plugs and see if there is water on any. Then do a compression test on all the cylinders. Liquid head-gasket sealer in my experience only works on heads and gaskets that are basically in good condition but have a slight seepage. The sealer will not close cracks, warped heads or head gaskets that are damaged. There is no short cut to solving your problem. And if you have water in the oil, you can kiss your bearing good by.
05/16/2010 10:47 PM
What particular bearing(s)?
05/16/2010 11:00 PM
all bearings that get treated with water are in danger of being damaged. That would be you mains, journal and may be the cam shaft. Water droplets in the oil turns to steam under engine loads and removed any oil film exposing metal to metal contact. Actually any part of the engine that needs oil lubrication is in danger of damage if there is water in the oil.
05/16/2010 10:50 PM
Water standing in the cylinders as documented in previous posts.
05/16/2010 10:49 PM
What type of car and which engine? Could be a leaking intake gasket and not a head gasket! GM v6's are known for intake gasket leaks which can get into the oil!
05/16/2010 10:57 PM
3.3 liter V6. The mid section was not very tight when I loosened it up. I will check the gaskets tomorrow to see if I can figure out the leak. What you say makes sense. The gasket of the mid section is something strange. On the other hand, the level of water in the cylinders was lower. When filling up the radiator always leveled to the same level.
05/17/2010 12:15 AM
There are only two types of GM V6's, those that are leaking and those that are about to leak! I have a 3.1 V6 with 60,000 miles and have owned it since new. I have already replaced leaking intake manifold gaskets twice and I see at least two or more every week that have this issue!
05/17/2010 12:23 AM
wow, any suggestions? Maybe leave a drain between the 2 heads? What is the torque for the heads? The gaskets are they all triple tin sheet metal? Thanks
Good Answers: 123
05/17/2010 7:19 AM
Thanks for the warning. I'll dump my 2.8L Chevy V6 before I get caught. I only have 310,000 miles on it, so it is still too early I guess.
Bob
05/18/2010 5:55 AM
That is very important, you MUST find the reason for the leak before proceeding.
I am shocked that you found water in more than one cylinder.
Also, I have the impression (maybe wrongly) that you experienced "hydraulic lock" in one of your posts, this can damage connecting rods and bearings.
You need to check carefully the top of the block(s) with a straight edge and a ruler.
Also the cylinder heads as well, in fact it might be a good idea (assuming its only a gasket) to have the head(s) lightly skimmed at an engineering shop......just to be sure.
Is it an engine that you can get cheap from a junkyard in a reasonable condition?
Good Answers: 123
05/16/2010 11:12 PM
What cylinder(s) had the water in them? Look closely at the area between the two valves. If the head is going to crack, it will do it where the metal is at it's thinnest, and the area is hottest. Scrub it well with a wire brush, and spray with brake cleaner, and let it set in the air. If there is a crack, it should show up as a rusted line. If you look carefully at the old head gasket, you should be able to see where the water was able to leak out of the coolant passages. If you can not see any reason for the water loss, think about having the heads professionally checked for cracking. Better to have them checked now, then after you reassemble the engine, and have leaks again.
If the engine is run with the water in the oil pan, the engine's bearings (cam, rod, and main) may be damaged. water does not provide protection from metal to metal damage. good luck.
Bob
05/17/2010 12:09 AM
All the cylinders had quite some water. After the engine ran hot, I tried to localize the water leak, but could not find one. The water disappeared to the engine and later I found out it was in the engine and in the oil pan. The engine has not been cranked during these tests, but it took some days. The heads are chrysler V6 - 3.3 liter. How are my chances to have cracks?Anyway tomorrow after inspection I'll know more. Thanks GA
05/16/2010 11:34 PM
please do not try any quick fix , head gasket is not the ordinary gasket , its very special gasket with some special properties , try to get it fix properly , do not waste time and money using quick fixes , same time you are damaging the engine while you are running engine with water mix oil , it might cause the serious damage to the engine .
ajit
05/16/2010 11:56 PM
Too late now, but I used Bardal's coolant leak repair last year & it worked great. They have several differnt products. The usual one iz for radiator leaks and wont work for leaks in the engine. The 2 that are for head gasket leaks and cracks in the castings are more expensive. The most expensive ( 30$ ) is used with the coolant in the system and I suppoze iz easier to use. I picked to 10$ version that requires you to drain and flush all the coolant out and then go thru a proceedure that takes over an hour. According to the instructionz, it will fill in pretty good size gaps and cracks.
If it turns out that you have a warped head and it leaks after you get it back together, you could try this stuff.
DQ OR DQ NoT. XeR IZ NO TRi. - YODU
05/17/2010 6:49 AM
It is very possible that you have a warped head (s). This can occur from overheating. The proper fix is to have the head surfaces checked for flatness and machined if within specification. Big expensive work, so you better LOVE the car.
Good Answers: 97
05/17/2010 6:34 PM
Okay here we have a Chrysler 3.3 OHV cast iron block with cast aluminium head V6. The intake manifold is either cast aluminium or reinforced plastic.
Which is yours a plastic intake or aluminium?
What came first chicken or egg is a past time for some...
There is always the condition where a leak caused the coolant to diminish and then the overheating occurs or vice versa. But in your case the previous operator has that information
An Aluminium heat to cast iron block can even under the best conditions leak and blow the head or intake gaskets or more likely the heads are cracked and if a plastic intake manifold??
05/17/2010 7:55 PM
The intake manifold is aluminium. The top cover is plastic
05/17/2010 7:48 PM
THE NEXT PHASE:
I took everything apart and today I cleaned and inspected the cylinder heads.
I ordered the gaskets and some other stuff in the US because everything has to be flown in.
The heads have a cast number:
04694688AA
I also see 11.A on it - The Chrysler Logo - and two circles with 9/0 in it and H/2. The heads have pushers and pivoters (? balances) that command the valves on top in the cylinders (OHV?). I will need to find 2 heads, if possible complete with valves, so that I only need to install them. Are these sets available or do I need to build everything over? And fix the valves and stems? I will ship from Florida (Ft Lauderdale Area) to The Bahamas. Can some one guide me in this? Thanks Van.
Good Answers: 97
05/17/2010 9:06 PM
05/17/2010 9:55 PM
nice sites. GA. and thanks. Van
Good Answers: 150
05/17/2010 8:43 PM
Do not, under any circumstances, use any silicone based gasket adhesives to reassemble this engine. Permatex makes a non-silicone based gasket adhesive (Form-a-gasket 2 I believe it is called.) that is ideal for this. Silicone based adhesives will release silicon into the exhaust stream which will poison the catalyst in your O2 sensors. You will be replacing O2 sensors like mad from there on out.
I would strongly suggest that you should obtain a can of dye penetrant and it's developer and check the cylinder walls and the heads for cracks that might not be visible to the naked eye but may open up under heat and pressure. It should be available at a welder's supply. But the stuff is pretty messy to clean up afterwards.
Who is John Galt?
05/17/2010 8:52 PM
The block is cast iron...
05/17/2010 8:58 PM
The motor block is also aluminium.
Good Answers: 97
05/17/2010 9:11 PM
It's not a 3.3 then maybe a 2.7 or a 3.5...
05/17/2010 9:49 PM
On the big black plastic intake box it is printed big:
3.3LV6
the head is a chrysler 04594688AA AB 11.A 9/0 H/2 Is that hole supposed to be there? Should I make a photo? Thanks
Good Answers: 150
05/17/2010 9:14 PM
You can use dye penetrant on any metal, you cannot use magneflux on aluminum but dye pen should be fine.
Who is John Galt?
Good Answers: 97
05/17/2010 9:20 PM
Ya okay I'm just cheap I guess
Good Answers: 150
05/17/2010 9:47 PM
were you "guest" that commented on the metallurgy of the block bwire?
Who is John Galt?
Good Answers: 97
05/17/2010 10:00 PM
NO
05/17/2010 9:17 PM
I found this site for heads:
What is the pcv hole at the end?
Please copy and paste:
http://flitelineenginesupply.com/index.php?main_page=product_info&cPath=3&products_id=216 Can I use this? What do I need to adjust here? The valves are in it? What about the shaft on top? Thanks for the help. Van
Good Answers: 97
05/17/2010 9:26 PM
PCV = positive crankcase ventilation; if you have a 3.3 engine then yes you can use it.
Go to the Mopar One link I gave and input the VIN# to be sure. Check here for 3.5L engine info
05/17/2010 10:04 PM
Thanks BWIRE - on the Napa site price list I see $319 - core $156 - does core mean I have to bring the old ones? How much they actually charge? Tried to call but the shop was closed already. Will check Mopar now.
Good Answers: 150
05/17/2010 10:08 PM
yep, they'll charge you the full price and then refund the difference when you bring the old one in as a return.
Who is John Galt?
05/17/2010 10:22 PM
Also with import? And a head full of cracks? The transportation and custom costs 2 way are a kill. I need to fly that in. Mopar One doesn't talk about a core.
Is that a recycling Law thing like batteries and tyres? I haven't seen any shops near Fort Lauderdale - Boca Raton area. I need to search some more. Thank you.
Good Answers: 150
05/17/2010 10:27 PM
No it's not a law, but what they do is ship them all back to the remanufacturing facility and they'll rebuilt the ones they can and sell the rest for scrap aluminum to offset the cost and ensure they have a steady supply of heads to rebuild. you aren't buying a new head I'd imagine, but a rebuilt one. Mopar sells new, not rebuilt.
Who is John Galt?
05/17/2010 10:46 PM
The Mopar price is about $130.00. But it is not clear if the valves are in it. They refer to a list in their catalog and all the parts are on a diagram. A bit confusing. How are they usually sold in the US?
Good Answers: 150
05/17/2010 10:55 PM
I can't say for sure, but generally when you buy a rebuilt head it comes complete with valves, valve guides, rocker arms etc. I've never bought a new one so I can't say for sure if you are buying just the casting or the assembly.
Who is John Galt?
Good Answers: 141
05/17/2010 11:27 PM
I will call tomorrow. Your help is greatly appreciated. For me the US car and parts market is totally new. I worked on European and Japanese cars but skipped two generations. Now, because of the vicinity of Florida, I bought my first American Transportation, turning out to be a lemon full of former liquid gasket experiments. The thermostat was removed and the interior heater bypassed. I should have known better. Though I want to repair this car as good as possible. A plus is that the parts are affordable and I can do the work. I went here in the local NAPA shop (there is one) but no gaskets, bolts, or cylinder heads available. They told me that had good "blue" liquid repair chemicals. I guess that is how the Bahamas repairs.
Plenty of room here
Good Answers: 97
05/17/2010 11:15 PM
The item is listed at Mopar One as "Cylinder head & Valves"
Good Answers: 97
05/17/2010 11:06 PM
The NAPA head is remanufacturered so they have a turn in core charge.
Mopar One is a "new" head no core required.
Good Answers: 141
05/17/2010 11:28 PM
I'll try to get it shipped to a US exporter in Florida. Thanks for the help.
Plenty of room here
05/17/2010 11:40 PM
I am with D now and he offered me some help. Thank you all. You made me do the job and gave me all good advise. I will keep you posted.
05/17/2010 10:15 PM
The VIN is only for when I call them. But it is a 3.3L6V. Do the heads come with the valves in? I need to build over the rocker shaft and use the same pushers? Is there any adjustment to do? I see no valve clearance adjustments. Is that hydraulic? Can I just install the new heads?
05/17/2010 11:34 PM
The hydraulic lifters should be pre charged with oil, other that that they are self adjusting. When the engine first starts, it may have a lot of lifter noise, but should disappear quickly.
Good Answers: 123
05/18/2010 5:56 PM
Sorry i am a little late on the response. In the Ft Lauderdale area, I can recommend a NAPA store I have dealt with for 25 years. M&H is on Broward Blvd. and SW 37 Ave, in Fort Lauderdale. They do a fair amount of exporting to the islands. If you would like their phone numbers, or E-Mail address, send me a PM. Bennett Auto Parts is also a large efficient auto parts business in the South Florida. I have some contact information for them also. If I can help you, again send the PM. Good luck.
Bob
In reply to #63
05/18/2010 10:14 PM
Thank you Bob, I really appreciate your help. Today I have been calling around for 2 heads after I checked the internet. I tried Mopar One, which looked great with $139.00 per head. I ordered, but had to cancel after they informed that the price was about $100.00 per piece more. For bare heads. Napa seemed tempting too with $319 and about $100.00 return for the core. The problem was that at the end, to build everything over. I ended again with $800-$900 for the two sets. Then I found Flite service in Arizona, and I think I have a fine deal there. They advertised one head, with valves for $112.00. The people were very helpful and didn't ask for a core. Send to Fort Lauderdale. it will have cost me $300.00 for both. I count also 70-80% shipping and taxes to Grand Bahama, but feel pretty good with this deal. Mopar didn't have assembled ones and Napa works with a guy who does the job for them. I expect everything next week and will keep you all posted. Thanks a lot for the help. D will do the assembly here.
Good Answers: 97
In reply to #64
05/20/2010 3:18 AM
I don't want to rain on the parade but I will $112 seems to good to be true...
Location: West Point, Texas population around 200.Located between Austin and Houston
In reply to #65
05/22/2010 1:06 PM
Junk yards depend on turn over.
Basically it depends on the junk yard.If they sell a LOT of parts then prices are cheap.I have bought a head for as low as 100 bucks only to find the block was also busted.((and the radiator(sent out for repair and returned with a shiny new black paint job)totally plugged))And then,if you can get a short block from a totaled vehicle for $350-400.would also be a good option.
Joe in Texas
We hold these truths to be self evident,one nation under God
Good Answers: 141
In reply to #66
05/22/2010 2:10 PM
Joe, check Flite service... this is new stuff. To be continued.
Plenty of room here
Good Answers: 141
In reply to #67
05/27/2010 12:32 AM
Today the two ordered heads arrived. I am very satisfied. Valves are and springs are in place and they withstood the liquid leak test. One head had a tread insert in one spark plug hole. I'll tell more when I have the engine to run.
Plenty of room here
Register to Reply 68 comments
ajitsaini (3); Andy Germany (1); Anonymous Poster (5); aurizon (1); bob c (3); bwire (9); cherryvan (22); dvmdsc (6); Engineering Superman (2); himart (2); Judge (1); lyn (1); peterg7lyq (2); Rorschach (6); Tobugrynbak (3); Z man (1)
