Previous in Forum: Calculating friction loss in hydraulic hose   Next in Forum: Welder Restoration.
insulation
02/17/2007 4:41 AM
HI
Can anybody help me out with the web site for getting information about insulation and insulation materials and also refractory materials for my use?
Re: insulation
02/17/2007 11:49 PM
What is the insulation for? I use Polyisocyanate foam board, blown with carbon dioxide and faced with aluminum foil both sides. Typically available in 48" x 96" sheets from 3/4" to 4" thick. Rated at about R8/inch and used for roof insulation. I use it for wine cellars. It is vapor tight when installed properly. Your question about refractory materials makes me think that the insulation above is not what you want because it probably catches fire at about 250º and outgasses nasty stuff. It is often called polyurathane and there is a brand called Thermax by "Cellotex" which is sort of yellow, and an equivalent grey material by another company. This is not the same beast as Styrofoam (White, pink, or blue) and these are generally less than half the insulation value. You can also insulate with "Foam in Place" if the job is big enough, and this can be alot of fun... Try Cellotex.com, and also Cellartherm.com
Re: insulation
02/18/2007 12:34 AM
what you wand i can help you.
Location: Lenox, Massachusetts, United States of America
Re: insulation
02/18/2007 10:20 PM
vmdke,
There is very good information on insulation materials and commercial sources of supply that you will find on the Globalspec site. Go to www.globalspec.com and to a search on the phrase "thermal insulation". You will find companies that provide many different kinds of insulation materials including the refractory materials that most interest you.
Once you have logged into the site, you can perform a parametric search (a search of specific properties that you desire) here: http://materials.globalspec.com/specsearch/suppliers/materials_chemicals_adhesives/stock_fabricated_materials_components/thermal_insulation_fireproofing_materials?SrchItem=4&RegEvent=login.
And, you can read more about insulation products here: http://materials.globalspec.com/LearnMore/Materials_Chemicals_Adhesives/Stock_Fabricated_Materials_Components/Thermal_Insulation_Fireproofing_Materials
Finally, you can register to receive weekly product alerts that will provide you with current information on new product offerings and new technology related to insulation here: http://www.globalspec.com/subscriptions/alertsignup.
Rather impressive resources, I say!
I hope you will share more information with the CR4 audience concerning your application and interests so we may help you.
Regards,
MillMatt
Re: insulation
02/19/2007 7:11 AM
Are you a globalspec spokesperson?
Engineering Fields - Piping Design Engineering - Environmental Contractor United States - Member - Born, raised and proud to be Texan Safety - Hazmat - New Member
Re: insulation
02/19/2007 7:49 AM
I don't know what your refractory needs are but try www.plibrico-usa.com for refractory materials. They have provided great assistance to me in the past.
Believe none of what you hear......and only half of what you see.
Re: insulation
03/08/2007 7:12 AM
Most insulation installation contractors will be happy to consider specific problems and offer suitable solutions for purchase.
Register to Reply 6 comments
Anonymous Poster (1); MillMatt (1); PatyO (1); Paul Wyatt (1); Pepper (1); PWSlack (1)
