Previous in Forum: Moulding Micalex   Next in Forum: insulation
Calculating friction loss in hydraulic hose
02/16/2007 10:38 PM
Can anybody explain how to calculate friction loss in hydraulic hoses?
The appx. size I am considering uses 5/8" and 3/4" ID steel fittings
Six months ago I couldn't even spell ing-a-near, now I-R-1
Good Answers: 120
Re: Calculating friction loss in hydraulic hose
02/17/2007 10:47 PM
RU? run through these. You should find enough clues to run this down.
http://www.google.ca/search?hl=en&q=%22fluid+friction%22+%2Btubing&btnG=Google+Search
Per Ardua Ad Astra
02/20/2007 4:34 PM
What you need is the BERNOULLI Equation!!!
03/08/2007 7:15 AM
Pressure drop in pipes was evaluated by Osborne Reynolds in the 1870s-1880s.
http://en.wikipedia.org/wiki/Reynolds_Number will help.
11/09/2014 11:17 AM
Dear Mr.DK Lost in Michigan,,
The Head Loss Formula is H = (4 x f x L x V^2)/(2 x g x D)
Where H = Head Loss in Ft., f = Friction Co-Eff., L = Length of pipe Feet, V = Velocity of Fluid in Feet, g = Acceleration due to Gravity, D = Dia of pipe in Ft.
The Velocity can be calculated once you know the Flow Rate and Pipe Dia.
Pl. refer any standard Hydraulics Text Book preferably by E.H.LEWITT,
DHAYANANDHAN.S
Register to Reply 4 comments
Anonymous Poster (1); aurizon (1); dhayanandhan (1); PWSlack (1)
You might be interested in: Hydraulic Repair Services, Hydraulic Cylinders
