Previous in Forum: Diesel vs. Gas-Powered Motor Home   Next in Forum: Greasing of Heavy Equipment
10 comments
Lubrication for Heavy Equipment and Trucks
05/23/2010 9:09 AM
As we all know heavy equipments are always very dirty , and almost all the grease points are covered by dust and dirt , and its not possible to clean or wash the whole equipment before greasing , and we also know if we grease dirty grease points , it harms all the bearings , any body has any idea or suggestion ,
how we should grease these equipments , is there any quick idea to clean the each and every grease nipple before we grease .
Re: lubrication for heavy equipments and trucks
05/23/2010 9:30 AM
  1. $3.69 used eBay Grease Zerk And Brake Bleeder Nipple Caps Or Covers Keep Yer Nipples Clean! Keep dust and dirt out of your fittings and ... for grease zerks but are also suitable for use on brake bleeder screw covers under .... Add to Shopping List
05/23/2010 9:42 AM
its not my company trucks and equipments , we are the maintenance company , we do maintenance for small customers , if we suggest any thing like that they might end up going some where else .
05/23/2010 9:43 AM
Never mind. Use a rag. If your customers don't want to protect their equipment, good for you.
Hobbies - CNC - New Member United States - Member - New Member
05/24/2010 7:10 AM
I can't believe someone would go somewhere else over a suggestion like this. It was my first solution when I read your question. If you are paid by the job and not the hour then how about just installing them and absorbing the cost. Buying in bulk makes these really cheap. On the other hand if you are paid by the hour then use a shop towel. I used to rebuild fertilizer equipment. I was paid the same if I ran a power washer, plasma cutter, welder, or rebuilt hydraulic components. Of course the decision also depends on what type of dirt needs wiped off. Soil and old grease is one thing. Wiping off limestone and cement dust is another.
05/24/2010 1:39 PM
GA.
Nobody thinks out of the box today......
Re: Lubrication for Heavy Equipment and Trucks
05/23/2010 11:33 PM
I believe that is why you will always find a clean wiping cloth in every mechanics back pocket. It is not suggested to use any type cleaning solvent as this will break down the grease and dilute the grease. Normally just clean the nipple and gun tip before applying.
Thomas J. Coyne, Jr., President, T.C.Inc., (an international project development/consulting firm).
05/24/2010 12:26 AM
A quick rag wipe and then just pump enough grease into the fitting that the first dirty bit gets pushed out again with the old grease - crude and wasteful but it does work. If you're in the repair business you don't want to keep things too clean or you'll work yourself out of a job.
05/24/2010 7:58 AM
A simple solution to a simple task!
oilcan13
05/24/2010 4:11 AM
It sounds as though your looking for the NASA ink pen solution to something which only required a pencil. The solution you need is to use competent tradesmen who will as a matter of professional pride wipe the fittings and fixtures to inspect them more thoroughly, before greasing anything..
05/24/2010 8:36 AM
Don't post the same type of question twice. Read the FAQ's.
Register to Reply 10 comments
Andy Germany (1); Anonymous Poster (4); lyn (2); oilcan13 (1); tcinc002 (1); The Mechanic (1)
