Hi all,
I am working on an idea to heat water by making it pass through transparent tubes that are partly filled with small black beads. The beads are caught inside the tubes between two sieves, so they won't escape. The idea is that the beads absorb the solar radiation and transfer the heat to the water. Cold water enters at the bottom of the near vertical tubes, making the beads whirl inside the tubes, and the heated water flows out at the top end.
I'm now searching for the proper type of beads. They should be small, (diameter about 0,5 to 0,8 mm), black and inexpensive. Preferably their density should be slightly higher than water, between 1,1 and 1,5. And of course they must be water resistant and non-toxic.
I am sure these beads must be available as off-the-shelf supplies for some kind of industrial application or other.
Any suggestions where to look are highly welcome. Thanks in advance!
