If I was to clean out a 55 gallon steel drum without asking my friends here for any advice, here is what I would do: I'd burn residue out, pour in some Simple Green and water and roll the thing around, and agitate, empty and rinse, then fill and test for water quality.
This cleaning is complicated in that I want to keep the top on the barrel. This project is intended to determine how to salvage 55 gallon steel drums to use as cisterns.
For the plastic 55 gallon drums, which often are used to store soaps, I have even less perfect ideas for the goal is to clean effectively without causing contamination of the yard, or local water.
For rainwater collection plastic barrels seem to be what they sell in the hardware store, but I wonder if steel drums might really provide less contaminated water?
P.S. What are the simplest water quality tests?
