Previous in Forum: implosion   Next in Forum: My 'Koken Chair'
Hot Water Cylinder Differentiation
05/28/2010 5:59 PM
Hi, I need help with a calculus qestion
To reduce heat loss, the surface area of a hot-water tank must be kept to a minimum. If such a tank is 125 litters in capacity, and can be approximated by a cylinder in shape with a hemispherical end cap; calculate the radius and overall height for minimum heat loss.
This is how far I've gotten:
The volume is the sum of the volume of a hemisphere and a cylinder.
The surface area is
Isolate h in the Volume equation.
Substitute for h into the Surface area equation.
Re: hot water cylinder differentiation
05/28/2010 7:52 PM
Don't have much, do ya?
Why not delete the, "cylinder in shape" and use two hemispheres joined at the middle?
Good Answers: 18
05/29/2010 5:17 AM
Ya think he might "get" that you're trying to steer him in the right direction, if that's "all he's got?"
Re: Hot Water Cylinder Differentiation
05/28/2010 8:28 PM
Two geometrical shapes must be taken into consideration. and if there are two end caps it is that of a circle and a cylinder. solve for h in terms of r in the volume equation, and use substitution in the second equation. then solve for r in the surface area equation. find when the first derivative of that equation is equal to 0. then you should find your answer.
"There isn't a scientific community. It's a culture. It is a very undisciplined organization." ~ Francois Rabelais
05/29/2010 12:25 AM
If h is the height of the cylindrical part, then h = 0; if h is the overall height, then h = 2r.
It depends on sorting out that ambiguity.
(This is just another way of saying lynlynch's GA.)
07/10/2024 6:49 AM
A sphere about twice the diameter of a soccer football fits the minimum surface-to-volume criterion; no calculus needed.
No mention of insulation or windspeed...
Bill (1); lyn (1); PWSlack (1); Shawn (1); Tornado (1)
