Previous in Forum: "Smart" Traffic Control?   Next in Forum: How Badly Will the Crude Oil Damage Our Ecosystem?
11 comments
Oil Leakage Stopper Strategy
05/29/2010 10:07 PM
Hi All,
My brainstorming idea for the petroleum leak is as follow, check this out: By having an strong made 'Stainless/Steel Screen Mesh' submerged donw there which will be wrapped or laying atop such leakeage spot (s) and brace with an arrange of strong earth magnetic blocks all over in order to have a good base for building up a heavy cluster layer over layer gradually which will be compost of dry coconut fiber and soft blend metals alloys until leak get seal out totally. A sideline atop or sideway valving connector will be addapt during this specially made clustering materials as need it. The valve is in order to maintain well further operation is possible, Who Know's?
In the meantime I'd modestly suggested the employ of few big freigth carriers equipped and modify with up front collector somehow like an standard carpet vacuum cleaner operate but 200 to 300 Ft. wide long to sweep out and sucking-up the contaminated water all over Gulf area in surface and pumping it inside the ship to a banks of 'Water/Oil Separators' units which will recycle the cleaned water back to ocean.
AllGood pal's let me know if this sounds nice and which are the chances in these approachs so far.
Crank That Puppy-Up,
MC
Re: Oil Leakeage Stopper Strategy
05/29/2010 10:13 PM
Oh GREAT we are saved. We can modify some big boats in about two months and suck all the oil up.
Let's get started.
05/29/2010 10:43 PM
moronicbumble! Is that you?!
05/29/2010 10:56 PM
I think you have the first half of the name right.
05/29/2010 11:00 PM
No. Moronic Bumble can spell, for one thing, and is often considerably wittier.
05/31/2010 2:52 AM
To add to my earlier reply, this is "magwer" rather than "MoronicBumble."
Good Answers: 130
05/30/2010 12:58 AM
You'd probably need some of these too;
3.4 Post Cold War
In the 1990s, the Malachite design bureau proposed plans for submarines capable of transporting petroleum or freight containers in or through Arctic regions. It was envisaged that these ships would dive under the polar ice cap to travel directly between European and Asian ports, and possibly northern Canada, with the designers noting that:
"Given equal cargo capacity, the efficiency of an underwater container ship is considerably higher, for example, than that of an icebreaker transport ship of the Norilsk type. The underwater tanker is competitive."
The tanker and container variants would follow the same design as standard military nuclear submarines, with the tanker variant carrying almost 30,000 tons of petroleum, to be loaded and discharged from surface or underwater terminals. The container carrier was to transport 912 standard (20-foot) freight containers, loaded within 30 hours through hatches, assisted by internal conveyance systems. However, these plans came to nothing in the hard financial straits following the Soviet Union's dissolution later in the 1990s.
A similar design has been proposed by the Rubin Design Bureau with the 'Submarine Cargo Vessel', a civilian redesign of the famous Typhoon class submarine of the Cold War.
United States
Overview
Similar to the post-Cold War ideas of the Soviet Union, there have been some concept plans to use atomic-powered submarine oil tankers to exploit Arctic oilfields in Alaska and Siberia. General Dynamics had apparently approached German shipbuilders during the early 1980s about the possible construction of either a US$725 million nuclear-powered or a US$700 million methane-powered version of a liquefied natural gas (LNG) submarine tanker to carry LNG from the Arctic to North America and Europe.
Good Answers: 19
05/30/2010 1:26 AM
?????? You are going against our last advertisement message of "We bring Oil to America".
_______signed
BP CEO
PS
Imagine if we go against our message America will sue us.
Good Answers: 101
05/30/2010 10:01 AM
Okay, we're just waiting for the comedians to start nicknaming BP "Bad Polluters".
05/30/2010 10:21 AM
It's even better than that:
Re: Oil Leakage Stopper Strategy
05/31/2010 3:44 AM
I sent BP a design to build a cage around the spill and surround it with Kevlar and build the cage up to a level where they could plant that containment thing they built on top, the one that iced up when thye tried to use it .
Remember BP wanted to cap this well and not produce from it till oil prices were over $80.00 a barrel to recoup their investment of drilling the well .
05/31/2010 5:04 AM
A post on the bittooth.blogspot - - Fine. Explosives have worked in some other situations. The critical difference in the Deepwater site has huge clathrate formations that likely contributed to the incident in the first place. If you advocate explosions, then you must also demonstrate the explosions will not destabilize the hydrates, or if so, that any consequences are manageable. Why the hydrates seem to be such a small detail to so many is really puzzling to those who are looking carefully at the situation. Unfortunately for the peanut gallery, nobody has ever been able to deal with hydrates yet- and not for lack of trying under even the best of circumstances.
34point5 (1); dadw5boys (1); ducon (1); DVader1000 (1); lyn (3); Mikerho (1); russ123 (1); Tornado (2)
