Previous in Forum: Generator Synchronization and Load Control with Mains   Next in Forum: Load Calculation
14 comments
Power
05/30/2010 2:34 AM
why root three is multiplied in three phase power?
Re: power
05/30/2010 2:49 AM
Three-phase (and for that matter other numbers of phases) can be modeled as vector diagrams. The length of the vectors corresponds to their voltage. Moreover, the phase angles in question also conform to the angles in the diagram. In the case of balanced three-phase, √3 is a common factor; it's just geometry.
Re: power
05/30/2010 3:20 AM
3 ph balanced power=3*1ph power=3*Vline/root3*Iline=root3 Vline*Iline
Better not count the cent if the risk is many many dollars.
Re: power
05/30/2010 4:35 AM
where did you find this?...in text books?...then answer will be already there. If you are working and it found in any documents, please ask your boss or who selected you there. He is responsible and ought to answer this type of question for the reason of selecting you.
Re: power
05/30/2010 5:20 AM
And also too many this question in CR4, search in the left box "serch this forum"
Got Something to Say?
Search this Forum
Electrical Engineering
Re: power
05/30/2010 7:57 AM
Mathematical equivalent
Correct me if i am wrong i am learner
Re: power
05/30/2010 8:29 AM
You will find your answer when you can apply Calculus and the classical thermodynamic law of the conservation of energy to a three phase electric power problem.
Re: power
05/30/2010 10:41 AM
A simpe search of CR4 would have lead you here
Re: power
05/30/2010 10:59 AM
Yes it would've, he should've and that was certainly an exceptional answer you produced then. But as far as why the square root of three instead of two, seven or some other irrational number to convert 3Ø voltages and amperages into real power does require some Calculus if one won't just accept the number. Then again, some people won't accept Calculus as an answer to anything too.
Re: power
05/30/2010 5:14 PM
RF, I believe my answer is why the sqrt 3 enter into the power calculation. It is a trig solution for sine wave problems. However I would like to see your idea regarding "You will find your answer when you can apply Calculus and the classical thermodynamic law of the conservation of energy to a three phase electric power problem." Can you provide a reference that I could check out.
Re: power
05/30/2010 5:38 PM
Just the simple derivation of root mean square calculation of the actual (real) power produced by each phase (Calculus). Combine that with the need to combine the power produced by each phase as opposed to the voltage of each phase and the current of each phase, for at any given instant in time since the three phases summation of the voltages and the currents equal zero for they are always 120° out of phase. Vtotal=V1(t)+V2(t)+V3(t)=0 Yet each phase must be adding power aka energy per unit time and energy cannot be destroyed. Thus making the requirement to do the RMS summing over a cycle. (Thermodynamics)
Re: power
05/31/2010 9:25 PM
Thanks for the information.
Re: Power
05/31/2010 4:31 AM
it depends how you are calculating
in a 3 phases system, power = line to neutral voltage * phase amp *3
there is no sq root 3 here,
if you use phase to phase voltage , phase to phase voltage = phase to neutral voltage * sq root (3)
it comes fom the fact that phase to phase voltage = vectoriel summ of two phase to neutral voltages, phase by 120 deg,
it is a trigonometric equation, sq root (3) come from sin(120 deg)
Re: Power
05/31/2010 2:33 PM
actually it is a mistake. somebody started with root three and everybody following it. I am using root 1. you can use any number if you are not an employee.
Reply Score 1 for Off Topic
Re: Power
04/05/2024 10:05 AM
Er, um, because it is the right answer?
Anonymous Poster (4); ikhanuk (1); Jans (1); PWSlack (1); redfred (3); Tornado (1); wareagle (3)
