Previous in Forum: How to calculate Blank Size Before Thread Rolling   Next in Forum: Service Rating - Class 150, 200, 300
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Pump Size Calculations
06/01/2010 4:24 AM
Can anybody help me out in estimating the size (dimensions) of the pumps.
At the initial stage of the project (at the time of Basic engineering), when vendor drawings are not available and we have to calculate the space requirements, then how would we proceed in calculating the space requirements of the pumps.
Atul singla
Pathfinder Tags: Pump size estimations
Re: Pump size calculations
06/01/2010 11:38 PM
For preliminary work, you might use a pipe velocity of 3 m/s (10 ft/s) for the pump discharge. The pump suction will typically be one pipe size larger. If you have catalogs ffrom one or more pump manufacturers that would be commonly used in your locale, this will give you some pump dimensions. A commonly seen requirement is for the suction inlet to have a straight section of length 6 x diameter. Add suction valve, possible strainer, possible discharge check valve, discharge valve, and other accessories needed. Add servicing/working clearances as appropriate. This will give you a total "footprint" for the pump. These numbers may be revised somewhat as you pin down an actual pump selection, but this should be a reasonable starting point.
06/02/2010 12:10 AM
It will help in deciding space requirement for pump piping, but first we need to calculate the pump dimentions so that we could calculate the space requiremnt for locating the pumps in our layouts.
Please throw some light on it.
Atul singla
06/02/2010 12:44 AM
That was the third sentence in the earlier post (#1).
Once you have estimated the pump flow and head requirements, make a tentative selection from virtually any pump catalog. Use those dimensions for a start. You (or some other specifier) must decide whether to use a close-coupled pump (motor mounted directly to pump) versus a frame-mounted unit (either with direct-drive coupling or belt drive). There are advantages and disadvantages for each of these choices; the close-coupled version takes up the least space.
Register to Reply 3 comments
