Previous in Forum: How to Select Starting Reactor for 3.3KV,1800hp Syncronous Motor   Next in Forum: Fuse Question
8 comments
Reducing Voltage
06/03/2010 12:48 PM
In one of my projects the voltage between neutral ang earth is 25volts. What will be the causes? How will I reduce it?
Re: Contractor
06/03/2010 2:03 PM
fix one reducer in series. I did it in so many projects and it is successfull
Reply Score 1 for Off Topic
Re: Contractor
06/04/2010 9:26 AM
What is that reducer? From where will i get it?
Re: Reducing Voltage
06/03/2010 5:05 PM
If the neutral was supposed to be grounded, maybe there is a loose or corroded wiring connection somewhere.
Good Answers: 60
06/03/2010 6:29 PM
is the earth a true earth ie is it connected or is there a high resistance to earth.
also how are you testing it .
neutral in the uk at the main incoming suppy comes from the same point as earth just to add to the confusion
http://www.google.co.uk/search?q=electrical+earth+and+nuetral&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7DKUK_en-GB&redir_esc=&ei=oiwITPPSOIT80wTS0NFn
06/03/2010 9:28 PM
Put an isolation transformer and connect the secondary to earth.
06/06/2010 4:26 AM
what is the voltage in your other projects??...what is your earth resistance?...what is the insulation test reading this phase and earth?... Do you have any sort of earth fault protection in the system?....Is there any surge arrestor installed in the main board?...
06/07/2010 5:19 AM
Earth is there as a protective conductor to operate the circuit protective device(s) in the event of a fault.
Power is supplied between phase and neutral.
So why is the neutral-to-earth voltage of any particular interest [rhetorical question]? It merely indicates that there are other unbalanced loads elsewhere on the distribution system! <sigh>
Good Answers: 170
06/08/2010 9:56 AM
Let it be so? Why do you bother? In what way it affects your load?
Anonymous Poster (3); David Hmingthanmawia (1); electricalexpert65 (1); peterg7lyq (1); PWSlack (1); Tornado (1)
